quick valve stem question, 2pc stems
Old Oct 24, 2008 | 04:21 PM
racebum's Avatar
Default quick valve stem question, 2pc stems
picked up a set of new rays 77 wheels with matching BFG KD tires new for 1k. i'm happy but am curious if you guys use locktight on these valve stems with the nuts?
Old Oct 24, 2008 | 08:49 PM
toyomatt84's Avatar
Sanji
Default Re: quick valve stem question, 2pc stems (idrivesideways)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idrivesideways &raquo;</TD></TR><TR><TD CLASS="quote">picked up a set of new rays 77 wheels with matching BFG KD tires new for 1k. i'm happy but am curious if you guys use locktight on these valve stems with the nuts?</TD></TR></TABLE>
They should have rubber seals inside the caps. They're there to prevent the caps from spinning off.
Old Oct 24, 2008 | 10:04 PM
racebum's Avatar
Default Re: quick valve stem question, 2pc stems (toyomatt84)
no, no, where they mount in the wheels. sorry, i should have been more clear.
Old Oct 24, 2008 | 11:01 PM
toyomatt84's Avatar
Sanji
I wouldn't put much on the stem base threads, either.
Old Oct 25, 2008 | 04:57 PM
racebum's Avatar
Default Re: (toyomatt84)
didn't want to unless there was a reason to. if they don't typically have problems coming loose i doubt i'll use any. it's a double nut setup so you can lock them against each other.
dpine
Jun 10, 2017 06:32 PM
Scotty Dosent Know
Jun 25, 2014 08:39 AM
99fbpem1
Aug 24, 2006 11:23 PM
hale_image
Jun 23, 2005 10:33 AM
b00stn
May 12, 2003 11:59 AM
