Car won't stay alive
Old Oct 24, 2008 | 03:10 PM
00siLS-V's Avatar
Default Car won't stay alive
Hi, I have a 00 civic Si with LS-V. I was cruising to work one day and all of the sudden my felt like it lost half it's power and right when i let go of the gas the motor just died. I started it back up but i had to keep giving it gas for it to stay alive as soon as I let go the car died again. I have no idea what is wrong. I switched my fuel filter but still nothing. Please help me! any advise is very appreciated! thanks guys!
Old Oct 24, 2008 | 03:14 PM
6footmidget's Avatar
does your rpm's jump up and down? and drops real low?
Old Oct 24, 2008 | 03:16 PM
turbojdmhatch's Avatar
Default Re: (6footmidget)
your going to need to give more information than that man....your car have the CEL on or what?
Old Oct 25, 2008 | 07:24 PM
00siLS-V's Avatar
Default Re: (turbojdmhatch)
CEL is on but my 02 sensor went out, rpms act normal it just feels like all of the sudden the engine lost all of its power, like there is not enough fuel coming in and as soon i let go of the gas the car dies! What could keep the engine from staying alive ? why did it lose power like if it had no compression or something. I don't see what could be causing this... theres really no way to check my CEL because i have a OBD2 to OBD1 harness and a del sol ECU or is there? What can i start checking for? Why does it die and lost half its power feels bogged! What other info do you guys need ?
Old Oct 25, 2008 | 08:56 PM
Unseen Racer's Avatar
Default Re: (00siLS-V)
wow that sucks.
well one way to fix that problem that will work FOR SURE is just to
sign the title over to me. yup yup.
that will fix you problemo. lol
Old Oct 25, 2008 | 09:58 PM
Default Re: (Unseen Racer)
try checking your ignition coil.
it might be messed up and it wont send a good voltage to the spark plugs.
and when you give it more gas, the extra gas gives it a better change to ignite
Old Oct 25, 2008 | 10:52 PM
Davus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00siLS-V &raquo;</TD></TR><TR><TD CLASS="quote">CEL is on but my 02 sensor went out,</TD></TR></TABLE>
This can cause some stalling and weird-runnings in general.
mkeacura
Sep 17, 2013 06:17 AM
usernamecr
Jan 25, 2008 06:49 PM
popeface
Apr 4, 2006 09:20 AM
urgonnalearn2
Mar 30, 2004 12:18 PM
