Opinions on T3/T04E 50Trim .68a/r
Old Oct 24, 2008 | 01:30 PM
dez6's Avatar
Default Opinions on T3/T04E 50Trim .68a/r
If you have used this turbo before I would like to get your opinion on its performance, at what rpm it achieved full boost, and how much power you made using this turbo, and finally if you would recommend it. My goal is to make 225hp-250hp on a d16z6. Thanks for any info..
Old Oct 24, 2008 | 02:05 PM
marcj's Avatar
Default Re: Opinions on T3/T04E 50Trim .68a/r (dez6)
I have the 57 trim on my b16 9:1 c/r setup, and it's a little laggy, but that works good for me cruising around town saving gas.. plus my goals are much higher than yours at around 20psi so it works..
in your situation, a T28 would suit you much better.. or maybe the same turbo with a .48 A/R housing. Find a WRX guy upgrading and snag his turbo
Old Oct 24, 2008 | 03:21 PM
dez6's Avatar
Default Re: Opinions on T3/T04E 50Trim .68a/r (marcj)
To run the .48A/R 50 trim i would have to use 5 bolt housing, Does the 5 bolt ford style housing not flow as well as a 4 bolt.
Old Oct 24, 2008 | 03:32 PM
legomytego's Avatar
i would say a little laggy if your set on using a 50 trim series i would use a t3t4 50 trim with the 63. a/r so it does not die off uptop or something like a gt28rs that would be a fun turbo if you have the money spool fast as **** and make a fun car
kccord
Jan 2, 2010 12:26 PM
boostjunkieee
Jul 13, 2009 07:53 AM
HickamHatch
Dec 7, 2006 05:51 AM
coupe_hybrid
Dec 4, 2006 07:21 AM
