How to install a Aem Uego wideband in Hondata S300 and Configure it to Work?
Old Oct 24, 2008 | 12:41 PM
sIrKicK's Avatar
Default How to install a Aem Uego wideband in Hondata S300 and Configure it to Work?
Hi, i have a hondata s300 with a aem uego wideband with gauge A/F ratio. I want to connect de 0-5v wire to hondata and configure the smanager to work with it and adjust af ratio in realtime with wideband. Is this wire to plug into de ELD on the ecu?... i connected it to the eld but doesnt works fine... could somebody help me with this?
Thank you!
Old Oct 24, 2008 | 01:59 PM
mtber's Avatar
Default Re: How to install a Aem Uego wideband in Hondata S300 and Configure it to Work? (sIrKicK)
Click help, click search tab, type wideband, hit enter.
Remove the resistors per the directions provided for logging via ELD.
Old Apr 16, 2011 | 06:39 PM
mmpg33's Avatar
Icon6 Re: How to install a Aem Uego wideband in Hondata S300 and Configure it to Work?
Where are the directions for logging ELD?? are removing the resistors required?
Thanks
Old Apr 17, 2011 | 05:33 AM
mtber's Avatar
Thanks
When using the ELD input, removing r136 and r138 is recommended to get a clean input signal. Concerning settings, read the help file (select open loop, select ELD for wideband input, set your voltages).
OEM1
Engine Management and Tuning
May 22, 2008 05:01 PM
texaszcrx
Apr 19, 2008 05:48 PM
Teamdiesel
Feb 2, 2008 08:42 PM
B00ST2nR
Jul 7, 2004 12:15 PM
spike
Dec 10, 2003 06:40 AM
