radiator question
Old Oct 24, 2008 | 06:31 AM
beana's Avatar
Default radiator question
i've been considering using an aftermarket (koyo,or fluidyne) dual core radiator made for an eg insted of the wide stock unit
i know it will fit with minimal fab work but i don't want any cooling problems in the louisiana heat
i'm running a built d16z6 w/stock water pump ,stock thermostat and a stock coolant temp sensor and better rad fan
the reason i want to run a smaller radiator is because i want to put the intercooler next to the radiator with a heat shield and two seperate ducts for each of them
Old Oct 24, 2008 | 06:34 AM
jdqcivicp72's Avatar
Default Re: radiator question (beana)
i would stay with the wide one for more cooling TMO. fmic causes car to run warmer
Old Oct 24, 2008 | 07:40 AM
89s1's Avatar
Default Re: radiator question (jdqcivicp72)
The EG rad is a dual core, technically has the same cooling surface as the EF full-width rad.
That being said. They fit like **** on the sock crossmember.
Old Oct 24, 2008 | 09:01 AM
beana's Avatar
Default Re: radiator question (89s1)
i was thinking about getting the full race radiator/traction bar combo but i don't want to have the overheating problem anyone use this setup
Modified by beana at 1:50 PM 10/24/2008
Old Nov 23, 2008 | 06:50 AM
fast4door23's Avatar
theres aluminum dual core radiators on ebay 4 like 80$
crxhybrid1320
Jul 1, 2011 06:01 PM
DEIVIONCRX
Jul 30, 2009 05:12 AM
misternguyen
12
Aug 6, 2008 12:01 PM
1 2 NV
Jan 31, 2007 08:38 PM
confucius
Apr 28, 2002 09:32 PM
