Flame if ya want-VTEC DPFI???
Old Oct 23, 2008 | 08:52 PM
nisk916's Avatar
Default Flame if ya want-VTEC DPFI???
Okay I have a longshot question. Is it possible to run the 88-91 dx DPFI on a VTEC head and block? I am eventually planning on the MPFI changeover, but funds are limited, and I currently have a deal on a d15b longblock. If running a vtec controller it it possible to run VTEC while utilizing the stock 88 dx DPFI? Sounds stupid, but is it possible?
Old Oct 23, 2008 | 09:11 PM
88Hatchy's Avatar
Default Re: Flame if ya want-VTEC DPFI??? (nisk916)
you will have issues with the dizzy, ecu, and injectors working together. In short, no.
Old Oct 23, 2008 | 09:19 PM
nisk916's Avatar
Default Re: Flame if ya want-VTEC DPFI??? (88Hatchy)
Even with using the stock 88 dx ecm and dizzy, maniforld ect? Not sure why that would cause complications. the VTEC would be an independent system from the Stock ecm and ignition system, right?
Old Oct 23, 2008 | 09:37 PM
D16SiHatch's Avatar
as long as you can get the dpfi dizzy bolted to the head, and you're retaining the stock intake then you should be fine. if i recall right i read somewhere that said the coolant passage that goes through the dpfi intake is different than the mpfi intake. which if true i gather may cause problems.
Old Oct 23, 2008 | 10:24 PM
EFinawesomeman's Avatar
Default Re: Flame if ya want-VTEC DPFI??? (D16SiHatch)
buy 2 headgaskets, try it out, if it doesnt work put the stock head back on and wait. then we will know for certain.
Old Oct 24, 2008 | 03:51 AM
dc5itracer's Avatar
Default Re: Flame if ya want-VTEC DPFI??? (EFinawesomeman)
I once had a hatch that i bought off this kid with a d16z6 but with the dpi setup but the vtec wasnt hooked up so i cant tell you if it would work or not.I see no pint in trying to hook up the vtec their will be no diffrence in power as far as i see
Old Oct 24, 2008 | 05:27 AM
beana's Avatar
it's possible if vtec is totaly seperate from the ecu ,and activated by say ,an rpm activated switch or a vtech controller ,but whats the point just swap the head and ecu and do the dpfi to mpfi conversion it'll save you a bunch of headaches
Old Oct 24, 2008 | 07:41 AM
Default Re: Flame if ya want-VTEC DPFI??? (beana)
no no. try it.
Old Oct 25, 2008 | 02:16 AM
therotaryrocket's Avatar
yea, just do it.
btw, a lot of people keep their OBD0 MPFI 88-91 SI intake manifold, ecu, and distributor with newer heads or engines. You can chip the ecu, but dpfi...idk, I imagine it would at least run.
Old Oct 25, 2008 | 10:15 AM
AmauryR's Avatar
Default Re: Flame if ya want-VTEC DPFI??? (dc5itracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5itracer &raquo;</TD></TR><TR><TD CLASS="quote">I once had a hatch that i bought off this kid with a d16z6 but with the dpi setup but the vtec wasnt hooked up so i cant tell you if it would work or not.I see no pint in trying to hook up the vtec their will be no diffrence in power as far as i see</TD></TR></TABLE>
Vtec can be controlled seperately, however it wouldn't fully take advantage of the system. Independant fuel/ignition maps when VTEC is engages/disengaged, intake manifold should work, dizzy might have to finagle with it to get it to bolt up. Unless your current cylinder head is shotl, I would wait for the rest of the components honestly. hth.
-l8r
Old Oct 25, 2008 | 11:04 PM
mario_pic's Avatar
not realy he can wire his vtec line to his tack light if its a 12 v light lol he can even ajust the shift point i did it b4 i figured out how to do my mpfi swap it dosent make much power just noise lmao lol
Old Oct 27, 2008 | 12:00 PM
nisk916's Avatar
Thanks for all the input. I think I may pick up the longblock, take my time,and get everything and do the mpfi and d15b swap and all at once. My stocker d15b2 does ok for now, so I'm no huge rush.
skateroyals
Jan 23, 2009 03:57 PM
ZCcivicBOI
Mar 3, 2006 04:32 PM
MrPotatoeHead
Mar 9, 2005 09:39 AM
Layziebtnh055
Apr 12, 2004 09:12 AM
