Few honda questions, please look !
ok, what kind of engine degreaser works good as im about to do a swap and would like to use some ??
also, will a lightweight flywheels help ??
and if i have an h-brace front upper strut and rear upper and lower strut will that improve anything at all ?
any engine degreaser will work.. just spray on and hose off
yes a light weight flywheel will help you rev up quicker
all of those struts will help improve handling a bit.. make sure you invest in the real deal and not ebay crap..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krysted9354 »</TD></TR><TR><TD CLASS="quote">ok, what kind of engine degreaser works good as im about to do a swap and would like to use some ??
and if i have an h-brace front upper strut and rear upper and lower strut will that improve anything at all ?</TD></TR></TABLE>
1. Simple Green works best
2. Sure, but on a stock motor you could probably get better gains elsewhere.
3. Yes, but getting shocks/struts and springs will be the biggest suspension improvement.
simple green just spray on wait and wash of right ?
and if i will have a 140 hp sohc then the flywheel should help right ??
and last whats a good ebay alarm system i can use ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krysted9354 »</TD></TR><TR><TD CLASS="quote">simple green just spray on wait and wash of right ?
and last whats a good ebay alarm system i can use ?? </TD></TR></TABLE>
Yes. Just be sure to cover your air filter and dizzy with a bag/don't spray directly on it.
Probably but the time and effort put into that, you could just as easily install a turbo and get a LOT more power. That's what I did.
Ebay is good but you have to know what you're looking for, I would personally go for clifford/alpine and not from ebay.
true.. dont invest in a light flywheel UNLESS you plan on changing your clutch anytime soon.. dont invest in headers or intake manifold either.. I would say work on suspension for now..
