Squeaky Suspension
Old Jul 29, 2002 | 02:17 PM
D16y8Joe's Avatar
Default Squeaky Suspension
I just had tokico illuminas and tokico race springs (a package deal I couldn't pass up) installed. This setup is amazing...but its squeaky as all heck. It sounds like it is only coming from the back 2, not the front. It isn't noticable at speeds above 25, but in stop and go traffic, as well as slow speeds (5-15mph) and getting out of the car, its incredibly squeaky. On the back, there are two metal bushings that sit between each side of the lower bolt on the shock, where it attaches on the trailing arm, could this be the culprit? Any help is appreciated, I have to get this fixed, it is driving me crazy.
Spade's Avatar
Default Re: Squeaky Suspension (D16y8Joe)
Get used to it and get a rear strut bar.
Old Jul 29, 2002 | 02:19 PM
D16y8Joe's Avatar
Default Re: Squeaky Suspension (Spade)
lol. So is there no way to get that damn sound to go away then?
Old Jul 29, 2002 | 02:20 PM
Spade's Avatar
Not ususally......most of the time it is the chasis. Siffer suspension makes things squeak that wouldn't on a softer suspension.
The strut bar may make it go away.....less flex.
Old Jul 29, 2002 | 02:28 PM
D16y8Joe's Avatar
Alrighty. Thank you sir.
Old Jul 29, 2002 | 02:49 PM
deepnite's Avatar
get some bushing spray and soak all the rubber bushings..if there polyurethane ones..soak them in silicone..should help but its just a temp. fix..only real fix is to go to energy suspensions and change out all the rubber bushings even then its not a sure cure
Old Jul 29, 2002 | 03:09 PM
RSZero1's Avatar
Default Re: Squeaky Suspension (9Grandr)
Yeah, a good temp fix is to get some silicone lube spray and just douse all your susp points with it. It is only temp but will help.
11psiGSR
Suspension & Brakes
12
Dec 6, 2011 01:07 PM
jacob1217
Mar 26, 2007 12:51 PM
SiR99
Jul 30, 2006 01:39 PM
HapiHonda
Oct 26, 2002 08:11 AM
RAB
Jun 26, 2002 06:31 PM
