AEBS SLEEVED B18C1 BLOCK $650
i recently had this in my car at 85mm and i thought i sunk a sleeve, but i had JJSpec racing in gray, GA check it out and it just needs a bore and hone if you want to use off the shelf pistons or if you wanted to use some custom pistons, then it just needs a hone; possibly a line hone. since its not ready to go as is, im only asking 500!!! FIRM!!! it has aebs t sleeves. it comes with the mains. any questions pm me. i have a golden eagle 85mm headgasket for another 75 if you buy it. otherwise its 90. i also have eagle rods for 250 and arp main studs for 50, water pump (4k miles) $40. The block is located in VALDOSTA, GA. sold as is.
bearing fixed? i spun a main bearing and tore it down and parted everything out. moving to valdosta and really dont want to bring this along. 500 firm. someone come get it
From: gravity rides everything...everything will fall, se GA/ne FL
how much of an overbore does the block need? and what kind of trades are you interested in? i'm about 2 hours away in saint marys, GA and i'm kinda interested...
