what ecu do i need for my b16a?
okay i dont know alot about hondas. i just a 93 integra 5sp with a b16a swap. it has the wrong ecu in it(it has a 92-95 integra ls ecu). it runs okay but burns way to much gas and the vtec doesnt work. it is an OBD1 hook up so do i just need a OBD1 ecu that is out of a del so or si civic and just switch them out to get it to run better?
OBD1 P30 or OBD1 PR3
both ECUs are available in other OBD versions so be careful when you're looking for one.
you can also pick up a chipped OBD1 VTEC ECU with the B16A maps in it. All though the stock ECUs I listed above will run better.
The advantage to a chipped ECU, it will allow tuning which will make the car run even better than the stock ECU. But it costs money and time, especially if you don't have anyone close by that tunes.
You should not be burning a lot of fuel when running the pr4 or p75 ls computer.
A chipped obd1 vtec p28 spec ecu would be the most affordable solution with the best performance advantage
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stangracer84 »</TD></TR><TR><TD CLASS="quote">anyone have one for sale? there arent any shops that tune where i live or any import places at all.</TD></TR></TABLE>
Check us out http://www.phearable.net we are a honda-tech sponsor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">
Good guys and great turn around time.
</TD></TR></TABLE>Good guys and great turn around time.
