Bolt on Radiator Support?
I crashed my car a while back and decided since it was wrecked i may as well do a 99-00 f.e.c. But i cut of my old twisted radiator support and was wondering if i could bolt my new one on incase i crash again or if i need to do an engine swap that it would make it that much easier to pull the motor.
let me know what you think
It would make me a a little nervous, but there's a DIY on an Integra JDM front end conversion where he bolts it on.
https://honda-tech.com/zerothread?id=1346217
I would not worry about removable rad. support. Especially if you plan on running some "traction bars" or some kind of cross member in the front to connect both "frame rails" (not sure if that's the proper term?). I am making a removable one that's just held with pins out of 1/2" tube. Similar to this one, posted by another HT member:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludeserge »</TD></TR><TR><TD CLASS="quote">I would not worry about removable rad. support. Especially if you plan on running some "traction bars" or some kind of cross member in the front to connect both "frame rails" (not sure if that's the proper term?). I am making a removable one that's just held with pins out of 1/2" tube. Similar to this one, posted by another HT member:
]</TD></TR></TABLE>
Nice looking shock setup there.
]</TD></TR></TABLE>
Just figure a way to bolt it on. It will be fine IMO. I have replaced one on my EG when i had it. It is very thin metal and and doesnt really seem to add much stiffness between the rails. It does just that radiator support.
92durtyintegraGS
Paint and Body
Dec 15, 2008 01:56 PM
beyondspexj
Dec 18, 2005 08:28 AM
