exedy oe replacement clutch kit any good for dd?
anyone recommend this clutch for dd. i know it's oe replacement but i saw a post once about exedy oranic clutch disc not be good. just need for dd.
I daily my gs-r with a stage 1 exedy clutch and pressure plate.. I love it.. the clamping force is a little stonger than oem which is good for some wheelspin when you get on it hard into 2nd at the track... cant say much about the oe clutch kit but as far as dd it I'm sure you wont have a problem...
i recommend it because i have a exedy stg.1 with a fidanza 7.5lb flywheel in my dd gsr it grabs hard chrips 3rd gear hard on the streets and 4th on the track.
the stage 1 is quite a bit stronger than the OE replacement. i also have one. however, it costs 3x as much. it all comes down to your goals and what you want to spend.
