no power to starter
Old Oct 23, 2008 | 11:04 AM
89CivicHb1's Avatar
Default no power to starter
im not getting any power to my starter. i checked the fuse box and the fuse for the starter is not getting any power either if anyone could give me any suggestions on what to do that would be awsome thanks
Old Oct 23, 2008 | 11:27 AM
redsi89's Avatar
Default Re: no power to starter (89CivicHb1)
you checked it and it's not getting power or it's just no doing anything. it might not be grounded correctly
Old Oct 23, 2008 | 12:58 PM
91DBSexyTime's Avatar
maybe it took a doo doo, get it tested.
Old Oct 23, 2008 | 01:07 PM
90sedan's Avatar
Default Re: (91DBSexyTime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91DBSexyTime &raquo;</TD></TR><TR><TD CLASS="quote">maybe it took a doo doo, get it tested.</TD></TR></TABLE>
It's not getting any power, so as of now, it's not because of a bad starter.
Check the starter ground and check the positive cable from the battery to fuse box. It's a pretty simple circuit.
Is the battery dead? Do you have any power?
Old Oct 23, 2008 | 02:59 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (90sedan)
my money is on the battery.. The battery can show 13 volts, but not have enough amps to turn the starter motor. Since it is getting colder outside, this problem also becomes more pronounced..
Most auto places have ammeters or a device to test the state of the battery, in terms of its amperage output, so i strongly suggest you try that before anything else.
Old Oct 23, 2008 | 03:16 PM
sgallagher's Avatar
Default Re: (sanimalp)
How did you test for power? +lead on the starter main terminal, -lead to the battery? That wire should always have battery voltage with or without the key on.
Check your ground to the engine. The starter completes its circuit through the case of the starter to the trans housing and back to the battery via ground strap to chassis-battery -.
If you do in fact test no voltage at the starter then you have a problem from the battery+ to the starter period. Check connections at the fuse box. Try jumping straight from the battery to the starter.
Old Oct 24, 2008 | 02:42 PM
89CivicHb1's Avatar
yeah i didnt realize i was talking about the starter solinoid and i forgot that i put a automatic wiring harness in the cabin and it didnt have the clutch switch cable the safty switch so does anyone have any ideas on how to make it work with out it? thanks to everyone that posted about the starter tho
Old Oct 24, 2008 | 03:08 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: (89CivicHb1)
you need to cut the clutch switch clip off and wire the 2 wires together.. then your ignition will be the only thing allowing power to the starter relay.. thats my best thought.. you may "non-destructively" try that to see if it works, because i am not 10,000% sure it will.
Old Oct 25, 2008 | 12:56 PM
sgallagher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89CivicHb1 &raquo;</TD></TR><TR><TD CLASS="quote">yeah i didnt realize i was talking about the starter solinoid and i forgot that i put a automatic wiring harness in the cabin and it didnt have the clutch switch cable the safty switch so does anyone have any ideas on how to make it work with out it? thanks to everyone that posted about the starter tho </TD></TR></TABLE>
If your interior harness is from an automatic you will need to jump the wires which would normally run to the park switch. They are large(about 12ga. wire) white with a black tracer, and they normally run down the center console. I put a switch between the 2 wires and hid the switch. I use it as one of my anti-theft devices.
Old Oct 25, 2008 | 02:14 PM
89CivicHb1's Avatar
those are both good ideas but im going to go with sgallagher's idea because i dont have the clutch wires thanks everyone for your help
Old Oct 26, 2008 | 02:40 PM
89CivicHb1's Avatar
i put the switch in and the car starts up thanks for everything
Old Oct 26, 2008 | 06:46 PM
EF_9's Avatar
check the wire that connects into it then take a metal bar and hit the starter and tell someone to start it if not then you need a new one
fleschrod
Aug 4, 2015 08:57 PM
mdrouillard1983
Jun 6, 2014 05:24 PM
JLefevers
Jun 5, 2007 07:05 AM
Lude@Heart
10
Jul 27, 2006 04:52 AM
ITR9788
Oct 13, 2005 01:34 PM
