Question about ITR manifold........
Old Jul 29, 2002 | 01:30 PM
avsrule414's Avatar
Default Question about ITR manifold........
I have a 92 hatchback with a 99 gs-r motor, it has a custom milled b16 head, type r pistons and rings, ctr intake cam, itr exhaust cam, cam gears, comptech sport intake, 2.5 inch custom exhaust, and dc 4-2-1 ceramic header. I plan on adding an icebox and itr intake manifold. My question is that I have heard an itr intake manifold is not worth using unless you rev 8k or over. Is this tru or not? Would the skunk2 intake manifold work better? Also, do I need to change the manifold gasket when I install the IM?
Old Jul 29, 2002 | 01:38 PM
bluesaint's Avatar
Default Re: Question about ITR manifold........ (avsrule414)
skunk2 IM and ITR IM is identical. Skunk2 basically copied the design of ITR's IM.
Old Jul 29, 2002 | 01:43 PM
avsrule414's Avatar
Default Re: Question about ITR manifold........ (bluesaint)
yea, thats what i thought. Anyways, is that tru about the itr manifold?
Old Jul 29, 2002 | 02:10 PM
bluesaint's Avatar
it doesn't start until 7krpm+
Old Jul 29, 2002 | 04:14 PM
avsrule414's Avatar
yea, so prob. right when the vtec starts to kick in. New gasket and throttle body necessesary or what?
Old Jul 29, 2002 | 04:15 PM
Toms96GSR's Avatar
i have heard that the skunk2 is alot better, that is what i am ordering!!!!!!!
Old Jul 29, 2002 | 05:09 PM
frogsr's Avatar
definitely the im gasket will need to be replaced. it'd be hard not to, since it gets caked on the head over time. throttle body is highly recommended to take advantage of the larger intake plenum inlet diameter. it's a great mod in my opinion.
Old Jul 29, 2002 | 05:14 PM
avsrule414's Avatar
Default Re: Question about ITR manifold........ (frogsr)
alright thanks, I should be ordering one soon.
Old Jul 29, 2002 | 05:16 PM
bluesaint's Avatar
pointless to get the ITR/Skunk2 IM without upgrading ur TB.
Old Jul 29, 2002 | 05:17 PM
frogsr's Avatar
forgot to mention, if you have the resources, you may want to look into the hondata im gasket. i found out about it after i installed my im. but it looks to be an interesting piece. just passing along some info i never had.
Old Jul 29, 2002 | 05:32 PM
avsrule414's Avatar
what do you mean have the resources? So...........would this ITR manifold come with everything I need if I bought it with the TB gasket http://www.inlinefour.com/typinman.html?
Old Jul 29, 2002 | 05:41 PM
frogsr's Avatar
looks like they're just selling the im alone. you'll need to buy the gaskets separately. resources=money.
Old Jul 29, 2002 | 05:44 PM
avsrule414's Avatar
no, if you click on the box it says TB gasket...........is that what I want or not? Yea, I may buy the hondata gasket.........looks good to me.
Old Jul 29, 2002 | 05:47 PM
frogsr's Avatar
oh, yeah. you're right. but that's for the throttle body to im mating. if you take off the tb, then it's always a good measure to replace the gasket anyways. the im to head gasket isn't included. that's where the hondata suggestion comes in. good luck.
Old Jul 29, 2002 | 06:02 PM
avsrule414's Avatar
so, I should buy the itr manifold with the tb gasket and the hondata gasket, would I have to buy new gaskets if I bought a skunk2 intake manifold as well?
david32391
16
Dec 19, 2012 02:56 PM
LD_EGSICK
25
Jul 31, 2003 08:30 PM
soloteg
Dec 1, 2002 06:03 PM
Brian_92GSR
Jan 31, 2002 11:35 AM
