Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
what is heel toe driving?
Old Jul 29, 2002 | 01:28 PM
F120man's Avatar
New User
Default what is heel toe driving?
ive heard about heel toe driving, but i dont know what heel toe does. why should i heel toe?
Old Jul 29, 2002 | 02:16 PM
Phoenix_ITR's Avatar
Default Re: what is heel toe driving? (F120man)
heel/toe downshifting is simply a way of matching revs as you go down through the gears. let's say you're braking fror a turn and you want to come from third gear down to second- you have the ball of your right foot on the brake, your left food depresses the clutch and you begin to shift from third to second. as you pass through neutral, use the outside edge of your right foot to rev up the engine before pulling it into second. the concept is to lessen the wear on engine components by eliminating the "shock" the occurs during downshifting. you have to heel/toe downshift in cars with dog-tooth gearboxes. it's not required in a car with syncros but it's generally not a bad idea. i hope this helps...
-tony
EDIT--i can't spell.
[Modified by delinquent, 11:36 PM 7/29/2002]
Old Jul 29, 2002 | 02:29 PM
Skunk2Civic94's Avatar
Default Re: what is heel toe driving? (delinquent)
heel/toe downshifting is simply a way of matching revs as you go down through the gears. let's say you're braking from a turn and you want to come from third gear down to second- you have the ball of your right foot on the brake, your left food depresses the clutch and you begin to shift from third to second. as you pass through neutral, use the outside edge of your right foot to rev up the engine before pulling it into second. the concept is to lessen the wear on engine compenents by eliminating the "shock" the occurs during downshifting. you have to heel/toe downshift in cars with dog-tooth gearboxes. it's not required in a car with syncros but it's generally not a bad idea. i hope this helps...
-tony
best explaination
Old Jul 29, 2002 | 02:34 PM
6ghatch's Avatar
-tony
It also help to keep the car balanced going into a corner. Just dropping the clutch, the car would "buck" and you could lose traction.
[Modified by 6ghatch, 4:30 PM 7/29/2002]
Old Jul 29, 2002 | 04:14 PM
Civic242's Avatar
Default Re: what is heel toe driving? (6ghatch)
Plus when you hit the corners Apex your in gear and ready to acclerate out onto the straight a way. It may seem as easy to downshift right at the Apex but those tenths of seconds will add up if your say on a 20 turn road course. Once you get the hang of doing it you'll be doing it on every corner you take and in every braking zone.
preludeNApower
Suspension & Brakes
Oct 19, 2011 05:13 AM
caliEG2dr
May 2, 2010 07:52 AM
hooptie157
May 12, 2002 06:07 PM
prelude10
Feb 5, 2002 12:33 PM
LSBeast
Jan 18, 2002 01:14 PM
