misfiring z6
Old Oct 23, 2008 | 03:11 AM
turboef90's Avatar
Default misfiring z6
so i have changed my fuel filter put fuel injector cleaner threw it. change my spark plugs there gap to 40mm. my timing is correct. i notice when it does misfire my rpm jumps down. i did a ohm test on my spark plug wires there still good and i change my dizzy cap and button not but 2 months ago. what else think it could be??
Old Oct 23, 2008 | 06:59 AM
TeamRPM_ZC's Avatar
Default Re: misfiring z6 (turboef90)
fireing order? and dizzy setting too low rpms?
Old Oct 23, 2008 | 07:58 AM
wrenchez81's Avatar
Default Re: misfiring z6 (TeamRPM_ZC)
check and see if one of the wires are carbon tracked!!!! this will allow the wire to pass a resistance check and still misfire..... look in the spark plug end inside and outside the boot and see if you can see what looks like lightning... try pulling each wire while the car is running to isolate what cylinder it is....
Old Oct 23, 2008 | 01:48 PM
turboef90's Avatar
Default Re: misfiring z6 (wrenchez81)
well my g\f has a z6 and it runs fine so i did swap spark plug wires and its still doing it. i also took each wire off and they all made it run ruff each one i took out.
Old Oct 23, 2008 | 02:13 PM
itsmejto's Avatar
Hope you swapped the spark plugs for recomended honda types, I've had missfire problems with platinum tips and it seems small honda engines prefere the old style fat tip plugs. TRy cleaning up the old ones, gap em to 35 thou. and try it.
Old Oct 23, 2008 | 03:20 PM
turboef90's Avatar
Default Re: misfiring z6 (itsmejto)
o ya ngks
Old Oct 23, 2008 | 05:34 PM
wrenchez81's Avatar
then isolate which cylinder.... then check the injector and do a compression test........ donsky!!!
Old Oct 23, 2008 | 05:44 PM
150sol's Avatar
Does it miss at idle, normal driving. or under hard acceleration?
Old Oct 23, 2008 | 06:06 PM
wrenchez81's Avatar
Default Re: misfiring z6 (150sol)
xxx2!!! throw us a bone!! be a lil more specific pleeeeze!!
Old Oct 23, 2008 | 06:10 PM
jimmy o.'s Avatar
is it throwing a code what year civic
tocoolforvtec
Feb 15, 2012 10:29 AM
banginryder16
Nov 23, 2007 06:32 AM
themex77
Mar 27, 2007 08:41 PM
menappi
Jun 29, 2006 03:06 PM
menappi
Jun 25, 2006 03:23 PM
