Accord emblem badge adhesive
Assuming I want to reapply my Accord badge on the back of my car, where can I find the adhesive, or something like it, to slap that sucker back on?
I've searched but all I can find are aftermarket emblems with the "peel & stick" backings.
I want real adhesive that will keep that on there..
x2 3M
I know it sounds week, but it kept my vent visors on my car for 6 years worth of wind, rain, sleet, snow, high pressure washers and drive through car washes. In the end I still had to scrape it off and use adhesive remover (spray nine) as well to remove it completely.
Ok, Im looking into the Double sided tape from 3M.
There are so many damn types!! Which one do i use?
http://www.tapecase.com/a.74.1....aspx
3M 9088 is the product number. It is 3M's white w/red lettered backed double sided tape. 3M 9088FL has a solid red backing on it. Both are clear when applied.
IIRC they also have green & black lettered backing. They are all of different thicknesses and strengths. The 3M Red product # 3M 9088FL, is what is used on most automotive trim parts that use double sided tape. The red has the widest temperature & moisture ranges for holding it's shear strength.
Edit*
I would think that a store like Wal-Mart or AutoZone would carry it Down in the US if Canadian Tire stocks it up here.
Modified by GhostAccord at 10:40 AM 10/26/2008
Modified by GhostAccord at 10:41 AM 10/26/2008
Edit*
I use 3M double sided tape. You can get a small roll of it at Autozone or Advanced Auto for like $5. Clean off all the old stuff, put the tape on the emblem, trim with a sharp razor blade, use alcohol to clean the cars surface, peel and tick it on. Hold pressure on the emblem for about a minute or so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan »</TD></TR><TR><TD CLASS="quote">3m double sided tape, close to the OEM stuff.</TD></TR></TABLE>
You can find this stuff at Home Depot, Lowes, Autozone, Advanced Auto Parts, Walmart, K-Mart, you get the idea.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NGUSPEED »</TD></TR><TR><TD CLASS="quote">
You can find this stuff at Home Depot, Lowes, Autozone, Advanced Auto Parts, Walmart, K-Mart, you get the idea.</TD></TR></TABLE>
this man is right
this man is right
3m makes a tube of auto badge adhesive too. Not sure if that's what they call it or not but it's for putting on emblems. People told me about it when I put a emblem in my aftermarket grille for my truck. I used silicone as they didn't tell me until after. The silicone is holding up okay how I used it but I think that other stuff would probably be better in most cases.
mckeand13
Mar 3, 2007 03:14 PM
