Transmission & Drivetrain Gearboxes, Differentials, Clutches
Transmission problem!
Old Oct 22, 2008 | 08:18 PM
ultradx's Avatar
Default Transmission problem!
I have a 2000 itr tranny, the passanger side tire shakes at around 65-75mph, i inspected my brakes, alignment, hub bearings and they checked ok. I picked up the front of the car and placed it on jack stands and i strap the rear end to ancher for safety. i noticed my passanger side axle as it rotates moves up and down like not center, so i went to buy a new axle and problem still there.
any suggestions?
Old Oct 27, 2008 | 08:50 PM
FerreiraCompetitions's Avatar
Default Re: Transmission problem! (ultradx)
Its probably your diff bearing that needs replacing. We can do that for you. PM me.
Old Oct 30, 2008 | 05:30 PM
slowcivic2k's Avatar
It is very possible you have a flat or high spot in the tread of the tire. Put each tire up in the air, and spin it to see if you got a flat or a high spot. Bent rim will do that as well.
If you feel it in the steering, its probably in the front, if you feel it in the seat, its probably in the back.
sublimeh215
Dec 4, 2009 07:40 AM
S1NFUL RL1 619
Sep 21, 2008 08:55 PM
jdmrex90si
Dec 27, 2007 11:25 AM
DraginTeg93
Nov 20, 2006 12:20 PM
rdblckSV650S
Honda Motorcycles
Jul 3, 2005 02:30 PM
