Neuspeed Strut bar Question
Old Oct 22, 2008 | 07:32 PM
Pjkf's Avatar
Default Neuspeed Strut bar Question
Will a Neuspeed 4 point strut bar that was formerly on a 90 accord fit on a 97 accord?
I know the suspension is the same. but are the strut mounts the same?
Old Oct 22, 2008 | 07:41 PM
P_Adams's Avatar
Default Re: Neuspeed Strut bar Question (Pjkf)
Bad news. The '94 thru '97 Accords use a three point upper strut mount. Even if it did bolt up, I doubt the bar will be long enough (The car's wider).
P
Old Oct 22, 2008 | 07:48 PM
Pjkf's Avatar
Default Re: Neuspeed Strut bar Question (P_Adams)
Well the neuspeed bar is one that bolts up to the 2 closest bolts on the strut towers. So yes there are 3 bolts on the tops but it only connects to 2.
Old Oct 23, 2008 | 06:38 AM
Pjkf's Avatar
Bump...
Old Oct 23, 2008 | 07:13 AM
GhostAccord's Avatar
The Neuspeed tie-bars are a fixed length 4 point bar. And I do believe, like P_Adams said, the chassis dimensions are different between the two Accords in question. It doesn't matter what bolt pattern it uses. If you want to check yourself take measurements from shock center to shock center on both chassis.
Neuspeed lists 2 different bars for the Accords between 90-97. So I would have to say it won't fit.
90-94 4 cyl = 35.20.90P
94-97 4 cyl = 35.20.95P
95-97 6 cyl = N/A
Old Oct 23, 2008 | 07:22 AM
Default Re: Neuspeed Strut bar Question (GhostAccord)
The measurement for the CD5 chassis is 941mm (37.04") now see if you can get the specs for a CB chassis.
Old Oct 23, 2008 | 02:26 PM
Pjkf's Avatar
Were was that measurement made from? What were the points?
The 2 closest strut bolts? the center of the strut tower openings?
Old Oct 23, 2008 | 04:27 PM
P_Adams's Avatar
If you've already got the bar in hand, just lay it in position and see if the bolt holes line up.
If not, measuring between the two Shock Strut shafts will give a rough approximation.
As mentioned elsewhere: If all these strut manufacturers list seperate Part Numbers for these different years, I would think it would be telling you something ... they are different (and won't fit)
P
Old Oct 23, 2008 | 06:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pjkf &raquo;</TD></TR><TR><TD CLASS="quote">Were was that measurement made from? What were the points?
The 2 closest strut bolts? the center of the strut tower openings?</TD></TR></TABLE>
The measurement was made from the center of the shock rods (tower openings)
Outlaw-Hondaz
Jan 27, 2010 01:52 PM
T^M
Apr 4, 2009 12:17 PM
SIC_WIT_IT
Feb 6, 2005 01:02 PM
stareatsun
Feb 18, 2004 06:46 AM
Kronic
Mar 7, 2003 10:42 AM
