Can't find CEL Plug on 1997 Honda Accord
Old Oct 22, 2008 | 06:02 PM
civicphreak's Avatar
Default Can't find CEL Plug on 1997 Honda Accord
I cannot find the CEL/Service Check Connector on my 1997 Honda Accord.
What's funny is that I have a 1995 Accord, and it's under the passenger side glove box. 2 Wire connector (red/green).
When I look for this connector on the 1997 model, the plugs don't exist! Did it change for this year model to somewhere else? The underside of the glove box looks different.
Thanks.
Old Oct 22, 2008 | 06:05 PM
TheMuffinMan's Avatar
He knows where you live!
Should be a blue connector under the glove box, it's in my 96 and works, so I don't believe they removed the connector in OBDII
Alternatively, remove the ash tray to get to the OBDII port and have Autozone scan it for free
Old Oct 22, 2008 | 06:06 PM
hondadude's Avatar
Default Re: Can't find CEL Plug on 1997 Honda Accord (civicphreak)
This is sorta top secret info.........
Your 97 is OBD2
Have you looked behind the ashtray?
Old Oct 22, 2008 | 07:33 PM
P_Adams's Avatar
The diagnostic plug for the scanner resides behind the console ashtray (it just pulls out). I was in there yesterday
P
Old Oct 22, 2008 | 07:43 PM
Guys, I believe he's referring to the blue service connector you can jump with a paperclip which is behind the glove box, rather than the OBDII port which is behind the ashtray.
Old Oct 22, 2008 | 07:44 PM
Default Re: Can't find CEL Plug on 1997 Honda Accord (P_Adams)
So I can't do the paper clip method on this? I've seen that OBDII port, so I might have to go to Autozone.
Old Oct 22, 2008 | 07:45 PM
Default Re: (TheMuffinMan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheMuffinMan &raquo;</TD></TR><TR><TD CLASS="quote">Guys, I believe he's referring to the blue service connector you can jump with a paperclip which is behind the glove box, rather than the OBDII port which is behind the ashtray.</TD></TR></TABLE>
EXACTLY!! Where is it?
Old Oct 22, 2008 | 07:52 PM
Should just be tucked up behind the glove box, my 96 has it in a small blue clip holder, next to an orange or yellow one up there.
I sit upsidedown in my seat (so my back is on the bottom) and look up behind the glovebox - should be able to see it then
Old Oct 24, 2008 | 06:22 PM
AP96's Avatar
I'd advise not going to autozone to have them check it out, that scan tool can pull a code but won't know the exact one.
I.E. Code for an O2, there's about 30 codes I bet for an O2 but they'll just say "oh it's your O2 sensor"
flashcad68
Sep 1, 2021 11:42 AM
AJHondaAcc90
Mar 3, 2018 05:02 PM
Frunkenstoom
Classic Hondas
Mar 18, 2011 05:29 AM
rockycat
Jul 27, 2009 08:48 AM
jDubb11
Mar 21, 2006 07:46 PM
