name these plugs and where they go!!!!!!!!!!
91 crx hf wiring harness with 99 y8 motor
the 2 wires here...1 green w/blk strip the other is yellow
im thinking they go to the reverse light switch
and these 2 plugs? i thnk the big one goes to the distributor, the other 1 not sure
Yes the two pinned wires by the head go to the reverse switch. And yes the big one goes to the dizzy, but the little one beside it does too. It has a big plug with all your sensors and a small 2-pin plug with power and ground.
I dont know the name of the wires but I can tell you where they plug into...if that makes any since. Sounds like INDYSPORTY is right though.
thanks indysport
oo sweetness then i was right... cool im learning to do my own swap..the other in the past been helping with friends...
soo now i just gota get my z6 dist on and plug and play right
Modified by EJ8CIVIC at 9:15 PM 10/22/2008
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC »</TD></TR><TR><TD CLASS="quote">thanks indysport
soo now i just gota get my z6 dist on and plug and play right </TD></TR></TABLE>
A d16z6 obd1 dizzy does not plug into the HF harness my man.
You could repin the connectors if you wanted or buy dizzy adapters if your not good with wiring!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC »</TD></TR><TR><TD CLASS="quote">oo i know that.. im lookn for the adapter
but i want to learn ho to depin...
how do u depin??????</TD></TR></TABLE>
http://fourthgenhatch.net/depin.html
try it on an old ecu u do not use for practice
im using an OBD2 one, just have to cut and re wire, I got mine on the 1st try.I put a 96 zc used my OBD0 plugs and sensors but had to use the OBD2 alternator, I think the bracket was different or something, it was over 2 years ago when I did it so memory a little fuzzy.
good luck, umm the ecu was repined because we did the mpfi. the car is still 0BD0 with the exception of the alternator. i will see what I can do about a pic, might be a pain the a$$ because im lazy, but i will reach down later and try to get one for ya, i only got a camera on the celly.
Oh yeah so what did you do about mounting the motor? did u use that bracket you bought from what was it napa? or did you take my advise in the other thread? using the old D15 bracket from the driver side and mount it on your new motor?
Modified by 91DBSexyTime at 2:36 PM 10/23/2008
well after bout 3wks waiting for the bracket to come in from this guy (from h-t) the d15 bracket
i use the d15 and the mount from ghettozone (autozone) it work out fine
yup it was.. piad on the 26 las month and got it last wk...
i really hate the usps.....
oo does it matter that the obd0 alt wire is lil thicker then the obd2 wire?
well ima bout to do this wireing and see wat i can do
weel if u dont mind can u txt me a pic of how u did the wiring
uhhh it shouldnt, i dont remember what mine looks like so haha, just make sure everything is twisted nice and tight and sealed from water, not that you guys have to worry about that too much...yeah just send me ur number and I will get u a pic to my best ability.
after i got the obd2 inj depin and i started to put the obd0 clips n tthe obd2 plugs, i found out they wont fit...it like tryn fit a rectangle in a cicrle
i guess i gota go to autozone to get those lil metal clips and cut and crimp onto the obd0....
and i
and i
i did my first depinning of the injector clips for both obd0 and obd2 hahahaha
