Wow look at this wiring. Plz help d16z6!
Old Oct 22, 2008 | 04:34 PM
z6htch's Avatar
Default Wow look at this wiring. Plz help d16z6!
Okay I have a 92 civic hatch with a z6 swap. It also has a si tranny. Look at this wiring. and I didn't do it before you blame me lol.
That lime green wire is supposed to run from the fire wall with a brown one down to somewhere on the left side of the motor. (Followed the brown and it looks like its a ground?)
But INSTEAD its ran back to the right and hooked to a blue wire from a different plug from the fire wall.
Any suggestion and would this be a reason I have a ELD, and IACV cel code?
Modified by z6htch at 8:39 PM 10/22/2008
Old Oct 22, 2008 | 05:12 PM
egsleepercivic's Avatar
do you have an aftermarket tach ?
94EG8's Avatar
Seagull Management
Default Re: Wow look at this wiring. Plz help d16z6! (z6htch)
That wire is going to an aftermarket tach, or possibly an RPM activated switch, the blue wire that it starts out as is the tach signal wire.
Old Oct 22, 2008 | 05:31 PM
z6htch's Avatar
Yes it does lol. Wow I feel stupid
Old Oct 22, 2008 | 05:36 PM
z6htch's Avatar
So the green and brown are coming from my aftermarket tach?
And the blue it the one that picks up the signal?
But I don't have a regular tach in my car. I'm lost lol
Old Oct 22, 2008 | 05:54 PM
94EG8's Avatar
Seagull Management
Default Re: (z6htch)
All I can see is what appears to be a yellow wire coming from the blue tach signal wire.
Old Oct 22, 2008 | 06:10 PM
z6htch's Avatar
sorry for the bad phone pics. its really a lime green wire hooked to that blue one. So the blue one is for a gauge cluster that has a tach like ex,si and such?
Old Oct 22, 2008 | 06:16 PM
94EG8's Avatar
Seagull Management
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6htch &raquo;</TD></TR><TR><TD CLASS="quote">So the blue one is for a gauge cluster that has a tach like ex,si and such?</TD></TR></TABLE>
Right where the splice is there would normally be a plug with a rubber cap on it. Technically that wire is called the "tach test wire" its so a technician can plug a tach in to monitor engine speed when working on the car. But it is often used as alternative to tapping into the blue wire going to the distributor when wiring in an aftermarket tach. That wire is not used for a factory cluster. Tachometer wiring is already present in all models so that an EX/Si gauge cluster may be used in any model with no wiring.
Old Oct 22, 2008 | 06:27 PM
z6htch's Avatar
Wow that helps alot thanks, I just thought It was someones hack job on the swap lol. But my car idles horribly up and down and around 2k.. I cleaned the IACV. Any ideas, You've helped so far lol.
Old Oct 22, 2008 | 06:34 PM
94EG8's Avatar
Seagull Management
The ELD CEL i can't specifically tell you about, other than I belive the actual ELD unit is in the engine bay fuse box. IACV might be bad, or someone plugged the wrong plug into it (common when an engine swap is done as their are 3 identical connectors right in that general area.) wire colors for the IACV should be blue/yellow and yellow/black.
Old Oct 22, 2008 | 06:38 PM
z6htch's Avatar
Okay I'll check that tomorrow and let you know. Thanks for all your help
HondaCivicSiR1
22
Dec 13, 2004 10:38 AM
92'gsrhatch
Jun 2, 2003 06:37 PM
Mike D
May 15, 2003 06:36 PM
NeedACivic
May 7, 2003 01:57 PM
Erik_Pb_Foot
Dec 3, 2001 08:02 PM
