d16y8 high compression engine tuned/converted to obd-1????
Old Oct 22, 2008 | 04:29 PM
1kleenef's Avatar
Default d16y8 high compression engine tuned/converted to obd-1????
I have a 96 ex with the y8 motor. It has a set of wiseco pistons and some head work done to it. I have the regular intake and header... Compression ratio is up around 11:1 My question is wether or not i would notice a difference if i converted to obd-1 and ran a chipped ecu and obviously got it tuned. Does this setup deserve a tune or would i not notice much difference?
Old Oct 22, 2008 | 06:41 PM
1kleenef's Avatar
Default Re: d16y8 high compression engine tuned/converted to obd-1???? (1kleenef)
bump this up
Old Oct 22, 2008 | 06:53 PM
iamthefollower's Avatar
are you talking about the ecu conversion??? Yeah it would totally run good if you get it tuned in... I know a guy here that has a single slammer like that but he has 13.1:1 compression, but it still runs like a raped ape.
Old Oct 22, 2008 | 07:37 PM
1kleenef's Avatar
Default Re: d16y8 high compression engine tuned/converted to obd-1???? (iamthefollower)
yes i know it will run decently im just wondering if its going to be a noticeable difference but yes i am just talking about swapping ecus and tuning it.
Old Oct 22, 2008 | 08:01 PM
You will definately notice a difference in it.
Old Nov 2, 2008 | 09:37 AM
JDM-JAMES's Avatar
yes of course i would get a chipped ecu with a custom y8 map on it
hondaluv!
11
Jul 24, 2013 12:09 AM
DC5Tuner
Jun 23, 2006 03:37 PM
quicksol95
Nov 20, 2003 06:46 PM
gocivicgo
May 28, 2003 05:30 PM
illmatic_si
Jul 7, 2002 11:11 PM
