Horrible clunking noises over bumps, axles?
Old Oct 22, 2008 | 02:19 PM
lmananT's Avatar
Default Horrible clunking noises over bumps, axles?
Whenever I drive over a speed bump or just random bumps in the road, my front passenger side makes a really loud CLUNK.
Driving and turning doesn't make any noises, just over bumps.
Sometimes while slowing to a stop, my right front starts to shake pretty violently like I have a loose wheel.
I had my axles replaced less than a year ago.
What could cause these symptoms?
Old Oct 22, 2008 | 02:27 PM
Alex_C's Avatar
Default Re: Horrible clunking noises over bumps, axles? (lmananT)
worn ball joints. When you inspect them there should be zero free play or "slop."
Old Oct 22, 2008 | 02:29 PM
lmananT's Avatar
i just checked and the balljoint boot on my passenger side is torn. could it be anything else? ill be changing the balljoints next week and want to get other things out of the way too
Old Oct 22, 2008 | 03:31 PM
Alex_C's Avatar
Default Re: (lmananT)
could be your bushings too. Check to make sure the rubber isn't rotten or cracked. You can get poly kits to make things stiffer or go with OEM rubber. I doubt it would be the axles....unless they make clicking/clunking noises when you turn a hard corner. That's about all I can think about right now though. Good luck!
Old Oct 22, 2008 | 03:54 PM
innes887's Avatar
im had the same problem, it was the rack. next time you have you car in the air grap the inner and outer tie rod and go up and down and you will hear the noise. i bought a new rack from a place my work deals with for 110 with the core! im 99% sure thats the noise your talkin about but also check the sway bar bushings, if there hard or egg shaped there prob gonna need replacing. if you need anymore help just ask
Old Oct 23, 2008 | 09:30 AM
lmananT's Avatar
thanks for all the help guys. im gonna get my rack rebuilt and get my bushings done while im at it. hope this solves my problem!
Old Oct 23, 2008 | 09:34 AM
pettyboy69's Avatar
when you lift it up in the air grab the wheel and push and pull side to side, then push and pull on the top and bottom of the wheel, if it moves side to side its somethin to do with the rack, inner or outer tie rods. if it moves up and down its the ball joints. also are you shure all your motor mounts are good?
Old Oct 23, 2008 | 12:03 PM
lmananT's Avatar
my motor mounts have cracks in it. does that mean they're done?
Old Oct 23, 2008 | 12:15 PM
sleepingciv's Avatar
could have a bad stut mount also
Old Oct 26, 2008 | 06:54 PM
Alex_C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lmananT &raquo;</TD></TR><TR><TD CLASS="quote">my motor mounts have cracks in it. does that mean they're done?</TD></TR></TABLE>
yeah, they are pretty much toast. BUT if they aren't too bad, you can get Energy Suspension motor mount inserts for around 30 bucks that will prolong the life of them - OEM mounts cost more. If I were you, I'd put my car on a lift and work my way through the whole drive train, shaking/jostling/yanking etc to see where the weak link(s) is/are. I personally don't subscribe to the school of "throw money at it until the problem goes away", so this might save you a few bucks if you can pinpoint the problem. Happy wrenching!
Old Oct 26, 2008 | 07:28 PM
88efZ6's Avatar
Check the wheel bearings while your in there doing all that work.
Old Oct 26, 2008 | 10:49 PM
lmananT's Avatar
so i just did my upper control arms the other day. while i was under there, i see now that my rack has tons of play on the passenger side. the boot is also ripped. the noise is definitely coming from the inner tie rod because i tried tugging on it and it is loose as a ****. after replacing my 20+ year old upper control arms, driving feels a bit more precise. clunking is still there from the rack but not as loud.
I'll be tackling the rack and pinion sometime next week.
Old Oct 26, 2008 | 10:53 PM
lmananT's Avatar
Default Re: (Alex_C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Alex_C &raquo;</TD></TR><TR><TD CLASS="quote">
yeah, they are pretty much toast. BUT if they aren't too bad, you can get Energy Suspension motor mount inserts for around 30 bucks that will prolong the life of them - OEM mounts cost more. If I were you, I'd put my car on a lift and work my way through the whole drive train, shaking/jostling/yanking etc to see where the weak link(s) is/are. I personally don't subscribe to the school of "throw money at it until the problem goes away", so this might save you a few bucks if you can pinpoint the problem. Happy wrenching!</TD></TR></TABLE>
thanks. im planning to change out all the suspension components eventually so spending a bit now will save me the trouble down the road.
i do see some red inserts on the rear mount that the previous owner put in, but it was only for that mount
Old Oct 26, 2008 | 11:05 PM
Alex_C's Avatar
i do see some red inserts on the rear mount that the previous owner put in, but it was only for that mount </TD></TR></TABLE>
what a jerk! I'm assuming the one that is cracked is the front engine mount, by the rad. Unless it's completely torn I don't think it would cause the problem you described. Checking your steering box/tie rod ends is a good idea too. Pretty much anything that moves that's attached to the wheels can make noise so your steering linkage is definitely a possible suspect. I think if your ball joints are fubar then replacing the entire steering knuckle would be your best bet. They should include the wheel bearing, which if worn could also give mess things up.
Old Oct 28, 2008 | 04:02 PM
lmananT's Avatar
im going to be replacing the lower ball joints this weekend. is there a way to replace them without removing the axles from the hub?
EK_B
Oct 9, 2011 05:21 PM
HondaHOVA04
Jun 16, 2007 09:12 PM
dc4teg95
May 15, 2007 10:24 PM
.Grimace
Sep 11, 2005 05:08 PM
