fuel dilivery problem
i have been having some weird driving problems nothing major but like wen its cold and i drive it every time i shift it seems to bog wen i release the clutch into the next gear and hit the gas i have a fuel leak somewere around the top of the tank i havent had time to pull the tank but one of my friends said somthing about a leak in the presure side of the fuel ddelivery system would this cause these problems and how hard is it to drop the tank is it a one hour job
do you have a lift or good jacks? it's not difficult, just unweildly. helps if the tank is empty too. there is a drain plug. if the bolts aren't rusted too bad, you could probably have it out in less than an hour. then you'll see what's leaking
turbologist
Oct 7, 2003 06:00 PM
