How to : jumper the service plug and lower RPM
Hi there,
I just ordered a cheap a$$ timing light, my timing need to be looked at since I removed my turbo setup and I see that I need to "Jumper de service plug" and lower the RPM. I searched a lot and everybody are saying that you have to jump it with paper clip... but where the hell is this jumper! And where is the paper clip going.
And how do I get the RPM to go at 750rpm at idle
The car is a 2000 Integra SE.
Thank you!!
Thank you!!
the service connector is located under the dash on the pass side under the glove box... you just put the paper clip to jump the two terminals
also here is another good thread.. I'm not sure what color our connector is though.. it's been a while since i had a CEL ::knocks on wood::
https://honda-tech.com/zerothread/1901557
