NEED HELP! I ran into a concrete pilon thing. Need advice
Old Oct 22, 2008 | 12:54 PM
fourdoorteg's Avatar
Default NEED HELP! I ran into a concrete pilon thing. Need advice
So after 2 and half years of driving max, i hurt him bad. I basically ran the front right wheel in to this concrete sign thing.
The wheel jammed into the fender well. It broke the front axle and also broke the tie rod. That was all the damage as far as i can see. But i have no idea.
Do you think this is repairable? Would it just be a matter of replacing both these pieces and maybe an alignment or am i [freak]ed?
I spent 600 on the car so ya know...
Old Oct 23, 2008 | 05:32 AM
phoenix_iii's Avatar
From: Close to West Chester, PA, United States of America
Default Re: NEED HELP! I ran into a concrete pilon thing. Need advice (fourdoorteg)
New tie rods (inner and outer), new axle, and maybe a camber kit... but heh, we need pics, and you need to look for stretched and stressed metal/frame damage.
PICS!!
Old Oct 23, 2008 | 06:28 AM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fourdoorteg &raquo;</TD></TR><TR><TD CLASS="quote">The wheel jammed into the fender well. It broke the front axle and also broke the tie rod. That was all the damage as far as i can see.</TD></TR></TABLE>
The lower control arm, steering knuckle, and rear crossmember are potentially bent as well.
Your best bet would be to source a complete right front suspension assembly and a rear crossmember (if needed) from a salvage yard. Make sure the ball joints and bushings are good. Get a new axle. Swap your brake parts onto the used knuckle. Get the car aligned afterwards.
Zendos
Aug 24, 2009 11:59 AM
wesk18
Jan 26, 2008 12:05 PM
See Are X
Apr 30, 2006 03:00 PM
Silent_Destruct
Apr 25, 2006 04:21 PM
mattL
Dec 29, 2004 07:35 AM
