plz help i swear i cant find the cel code
okay i have a 93 cx hatch with a d15b7 in it manual transmission as well as matching d15b7 ecu..
i have a cel code or atleast it says i do.. i jumped the connector like u are supose to but when trying to count the flashes all it does is flash on and off in 4 second intervals and never stops or has a longer pause.. iv sit watching this thing for 10 minutes now and it never restarted or paused longer then before...i can count 1 1000 ,2 1000, 3 1000, 4 1000 between intervals..
everytime i look up the code it dosent exist and i have no idea what it is iv checked and cleaned and replaced everything that could be at fault
u can scan a obd1? i thought it was only obd2 that u used scanners on hell ill take it tomorrow then.. i donsent seem to hurt performace just annoying that its on.
oh and also mine is the cx model like i said and it as that upshift green arrow light that comes on well it used to come on but now it dosent and i think its related to the problem if anyone knows what would cause that not to work
ekhonda87 is right the 1 second flash would be cel-10~ IAT, n the 1/2 second is cel-1~ o2 sensor, the long pause in between is the cycle, if no more codes are present it cycles the same code. The AutoZone scanners are obd2 and as far as i know they don't do it any more. u are doing it right wit the jumper.
question... when u re-set the ecu how long does it take for the cel to come back on?
yes i understand how the codes work but every flash is longer then 1 second and there are no fast flashes .. i even unpluged other stuff to see if it would flash right and it does. and after i reset the ecu the code comes back almost immediatly.
i swear if i had a cam i wuld video tape it. i think it might be the white plug on the back of the intake manifold.. if i unplug it the code dosent change or flash a different one. it has 2 wires going to it and 1 of em is green.
but the code never recycles each and every flash for as long as u want to watch is the same
okay and today now it is extremely hard to get it to rev over 3k.. it will but it takes a century.. and now my oil light is on but the sensor is hooked up and the oil is full..
could i be dealing with a faulty ecu? if it was wouldnt the cel just stay on instead of flash?
okay i took a video of it this isint the full thing cause my cell only takes 15sec videos.. but the spacing is the same for all the flashes no matter how long u watch it and it never ends<object width="425" height="350"> <param name="movie" value="http://www.youtube.com/v/NGUbeZw00DQ"> </param> <embed src="http://www.youtube.com/v/NGUbeZw00DQ" type="application/x-shockwave-flash" width="425" height="350"> </embed> </object>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMekBoosted »</TD></TR><TR><TD CLASS="quote">take it to advanced auto or auto zone and have them hook up the scanner they can get you the code and its free</TD></TR></TABLE>
Most auto stores can only read OBDII for free. OBDI is a little different and they don't usually have the connectors for it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Icon_Ed6 »</TD></TR><TR><TD CLASS="quote">The AutoZone scanners are obd2 and as far as i know they don't do it any more.</TD></TR></TABLE>
Yes, we do.
The video looked like one long flash to me. So, 10.
http://check-engine-light-code....html
Yes, we do.
i think NOFX is correct, after watching the vid, i would definitely call that a 10. Also, the white plug on the back of the in-man wit 2 phillips screws in it that u referred to is the IAT. BTW AutoZones around here don't pull codes any more, they won't even let u do it yourself. I guess its a local thing.
