I Think My Engine Jumped Timing After a Cam Gear Install! *HELP!*
Old Oct 22, 2008 | 12:13 PM
jhonda239's Avatar
Default ****** I NEED HELP, THIS SUCKS *****
ok, i put an aem adjustable cam gear on my car because i got it as a trade from a friend. so i got it installed and everything and the timing belt seemed to be tight enough. so i take it for a test drive, come back and check everything, and everything seemed to be good. i guess i overlooked the marking on the cam gear/ belt, but i was showing my friend and i noticed my belt jumped 7 teeth. the cam gear was at stock setting, and the car is a 97 civic ex. i drove the car home and it seemed to be fine.
i need to know if u think it bent my vaves or messed up anything else.or if u have some advice. i didnt hear any odd noises either
Old Oct 22, 2008 | 12:29 PM
blkegcoupe's Avatar
From: ....................................................................................................
wow, thats all i have say.
but how did you find out that jumped 7 teeth?
what must've have happened was the timing belt tensioner was not tightened down good.
it happened to me when i did my headgasket.
but to find out if you bent anything at all is to do a compression and or a leakdown test.
from what i know is that a leakdown is much more effiective.
what i would like to know is was it still running when you checked it? does it idle smooth? how does it run when you drive it?
Old Oct 22, 2008 | 12:33 PM
whereiscarmensandiego's Avatar
not sure how u could have had the belt loose enough for it to jump 7 teeth are u sure that the gear was tightened down correctly or its not striped? and if u managed to drive it home and not even notice anything im sure nothing is wrong.. it would be clacking and making all kinds of scary noises if the valves or anyting was bent
Old Oct 23, 2008 | 01:50 AM
jhonda239's Avatar
Default Re: (blkegcoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blkegcoupe &raquo;</TD></TR><TR><TD CLASS="quote">wow, thats all i have say.
what i would like to know is was it still running when you checked it? does it idle smooth? how does it run when you drive it?</TD></TR></TABLE>[QUOTE=blkegcoupe]
i made a mark on the timing belt and cam gear right after i installed it. and yes it idles smoth and runs fine, but wen i drove it home i was shifting at 3k
Old Oct 23, 2008 | 10:25 AM
95streetciv's Avatar
Default Re: (jhonda239)
i dont think the mark you made on your belt and cam gear are going to line up on every trip around the belt.
I bet your fine and didnt jump any teeth.
Recheck your OEM timing marks.
Old Oct 23, 2008 | 10:58 AM
CRX T-Si's Avatar
Default Re: (95streetciv)
If your looking at the mark you made on the TB then forget it. The mark you need to be looking for is the one on the crank pully to make sure that it's lined up with the arrow head.
Then making sure the cam gear is lined up with the head.
Old Oct 23, 2008 | 11:01 AM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95streetciv &raquo;</TD></TR><TR><TD CLASS="quote">i dont think the mark you made on your belt and cam gear are going to line up on every trip around the belt.
Recheck your OEM timing marks.</TD></TR></TABLE>
Old Oct 25, 2008 | 03:08 AM
jhonda239's Avatar
Default Re: (littleblue)
but when the mark i made on the cam gear is pointing up, the mark on the belt is 7 teeth over. that mark is supposed to be lined up.
Old Oct 25, 2008 | 03:46 AM
madracer's Avatar
When you start the car now does it idle normal and drive normal.???
You can't go by the mark you made on the belt, the cam gear have to make many turns before that belt will come back to the top where you made the mark.
Old Oct 26, 2008 | 02:39 AM
jhonda239's Avatar
Default Re: (madracer)
then how am i supposed to tell if it jumped or not. i only drove it for 10 mins after i noticed the belt and it ran fine.
Old Oct 26, 2008 | 03:08 AM
itsmejto's Avatar
if indeed it did jump 7 teeth, it would run like **** and damage the valves against the pistons.
IT"S OK, forget the belt mark and check the pully marks.
Old Oct 26, 2008 | 05:26 AM
jhonda239's Avatar
Default Re: (itsmejto)
where do i find the oem/factory marks. where r they on a d16y8
Old Oct 26, 2008 | 06:03 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhonda239 &raquo;</TD></TR><TR><TD CLASS="quote">where do i find the oem/factory marks. where r they on a d16y8</TD></TR></TABLE>
No offense but why would you install a cam gear if you don't know where the TDC marks are on the engine?
You set everything at TDC FIRST before you do any timing belt related work.
Do you have a lower timing cover? If so there is a sight line or nipple on it that you need to line up the timing mark on the crankshaft. The mark on the crank pulley is the white one all by itself.
Once that is lined up you need to make sure the TDC timing mark on the cam gear lines up with the marker on the inner plastic timing cover behind it.
If everything lines up you're fine. Again for the 6th time you cannot judge anything by a mark you put on the t-belt itself because when the engine rotates it's not a perfect 1:1 ratio therefore it will look off most every time you look at it.
Old Oct 26, 2008 | 07:48 AM
littleblue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhonda239 &raquo;</TD></TR><TR><TD CLASS="quote">but when the mark i made on the cam gear is pointing up, the mark on the belt is 7 teeth over. that mark is supposed to be lined up.</TD></TR></TABLE>
The cam gear spins faster then it takes for the belt to make a full rotation therefore the mark on the belt will only once be on the same mark a sparse amount of time.
Have you ever tried to sync your turn signal with the car in front of you? You will notice that only one to two blink will ever be in sync. Same goes for the timing belt
Old Oct 26, 2008 | 09:28 AM
jhonda239's Avatar
can any1 post up pics of all the timing marks for a d16y8.
Old Oct 27, 2008 | 08:28 AM
TravisCadello's Avatar
You'll know if you jumped 7 teeth.
Old Oct 27, 2008 | 09:08 AM
B18C5-EH2's Avatar
Former Moderator
Loved
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhonda239 &raquo;</TD></TR><TR><TD CLASS="quote">can any1 post up pics of all the timing marks for a d16y8. </TD></TR></TABLE>
The problem is, and why I've not answered your Q about cam timing mark/marks, is that you have an aftermarket cam gear. I can tell you that the stock cam gear has it's timing marks at approx. the 3 o'clock and 9 o'clock postions and they are to line up level with the cylinder head's deck surface while the "UP" is facing up on the gear.
Aftermarket cam gear? Who knows? Hopefully it has exact marks in the 3 and 9 o'clock postions, but I don't know.
Old Oct 27, 2008 | 11:59 AM
jhonda239's Avatar
Default Re: (B18C5-EH2)
turns out everything was fine. d16y8's apparentley have automatic belt tensioners.
Old Oct 27, 2008 | 12:02 PM
93egSLEEPER's Avatar
if you would have jumped 7 teeth you wouldnt have driven your car anywhere. period
Old Oct 27, 2008 | 03:18 PM
itsmejto's Avatar
Default Re: (93egSLEEPER)
he's just not listening cos the answers don't make sense to him yet. Just got lucky putting it back together I guess.
Why he change it without understanding timing marks is beyond me.
Old Oct 27, 2008 | 03:59 PM
trrbl1bmx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jhonda239 &raquo;</TD></TR><TR><TD CLASS="quote">turns out everything was fine. d16y8's apparentley have automatic belt tensioners. </TD></TR></TABLE>
Are you serious??!?! 1 tooth off on a t-belt will make your engine run like **** if at all. You shouldn't be working on your car with out a manual like previously stated. And for the record unless you have some crazy jdm d16y8 that is a one off engine from honda's assembly room, you sir do not have an automatice tensioner.
Old Oct 27, 2008 | 05:15 PM
jhonda239's Avatar
Default Re: (trrbl1bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trrbl1bmx &raquo;</TD></TR><TR><TD CLASS="quote">
Are you serious??!?! 1 tooth off on a t-belt will make your engine run like **** if at all. You shouldn't be working on your car with out a manual like previously stated. And for the record unless you have some crazy jdm d16y8 that is a one off engine from honda's assembly room, you sir do not have an automatice tensioner. </TD></TR></TABLE>
a tech at honda, which has been a tech for 30 years and owns a 98 ex coupe(d16y8) told me that
Old Oct 27, 2008 | 05:18 PM
aeenox's Avatar
yea cause mine had jumped 2 and then it wouldnt even turn on.
Old Oct 28, 2008 | 07:52 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: ****** I NEED HELP, THIS SUCKS ***** (jhonda239)
Well this assumes that you installed the cam gear without the camshaft moving at all. since you did not even know to line everything up at TDC and recheck after the install there's a good chance it's off a tooth or two regardless of the engine having an auto tensioner.
Also unless you literally loosened the tensioner bolt and let the spring pull the tensioner out and pull slack out of the belt then it doesn't matter about the "automatic" part of the tensioner if you don't know how to actually engage it.
jetspeedz
Aug 18, 2009 01:45 PM
Slammd Sol
18
Aug 15, 2005 05:48 PM
EK4 hatchback
May 31, 2004 08:45 PM
xerox445
Mar 2, 2004 02:05 PM
Lightning Lover.
Nov 30, 2003 06:46 PM
