depinning OBD-1 injector clips
Old Oct 22, 2008 | 10:24 AM
jewpont's Avatar
Default depinning OBD-1 injector clips
are the OBD-1 injector clips depinable so that i can just pin in the wires so as not to cut n connect the wires to change my OBD-2 clips to OBD-1?basically i want to swap from OBD-2 to OBD-1 injectors, but instead of cutting the OBD-2 clips off n have butt connectors n things, was wondering if u can depin the connectors n put the pins in the other clips. the OBD-2 clips look like i can depin them, but the OBD-1 do not, is there a way?
Old Jul 10, 2009 | 05:18 PM
NAEGH22's Avatar
Default Re: depinning OBD-1 injector clips
did you work out whether this is possible?
does anyone know how to depin obd1 injector clips?
Old Jul 10, 2009 | 05:53 PM
94EG8's Avatar
Seagull Management
Just pull the blue insert out of the OBD2 injector clips and they'll fit on OBD1 injectors, you will need to tywap them to the injectors though as they no longer snap on properly.
Old Jul 10, 2009 | 06:05 PM
NAEGH22's Avatar
are the obd1 injector clips depinnable though?
nolakid504's Avatar
you can de-pin them the same way.. pop the top and stick something super small into the clip and wiggle until the flat pin comes out.
Old Jul 10, 2009 | 06:11 PM
Linh.'s Avatar
Pull the rubber piece off then pull the plastic clip off. After that turn your injector plug around so your looking at the pins. Stick your flat head screw driver down the side that has the gap. All you have to do is push your flathead screw driver againist the pin and pull the wire out.
Old Jul 10, 2009 | 09:38 PM
NAEGH22's Avatar
ok. thanks for the advice Linh. It worked. Just pried the rubber seal out the back of the connector, then got some long nose pliers to pull out the plastic tab that sits under the rubber seal. Then it's depinned as any normal connector.
Next question, has anyone found a part number for new replacment injector connectors or new replacement pins?
I've found a connector bosch make but they're pricey and i'm not sure whether they'll work.
It's similiar to the injector connectors in this pic -
Old Jul 11, 2009 | 01:24 PM
Linh.'s Avatar
Try talking to Ryan @ Rywire Im sure he could probaly sell you some
Maleek
May 17, 2012 08:47 PM
BB6matik
Aug 15, 2010 05:54 PM
Black R
Nov 10, 2007 04:31 PM
EKB18BPR3
May 6, 2005 08:07 AM
