z6 dizzy on y8 head
ok iv search and nothing on which to cut
i got a d16y8 and a z6 dizzyin my 91 crxhf
im fixing to put the z6 dizzy on and b4 i cut the wrong bolt tap (ear) off which one do i cut off to make it fit right?
if u guys can help that be grrrrreat!!!!!!!!!
and post a picture of it plzzzzz
Use the d16a6 dizzy, it bolts right up on the y8 head!
edit: wait you have a p28 ecu, then yea you have to use the z6 dizzy then. well you can always put it on and see what bolt will bolt up and for the last tab you can cut it off? Wont it leak if you do this?
im puting a 92-95 d16z6 dist on a 99 d16y8 vtec head and i got a p28...all this is going into my 91 crx hf
and its been done b4 that ppl said that u wud have to cut off a bolt tap
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mario_pic »</TD></TR><TR><TD CLASS="quote">use a 92-95 civic dx 1.5 dizzy non vtec tho it will im running it now in my y7 y8 mini me and my 91 civic works mint no drilling grideing to make it fit</TD></TR></TABLE>
Beat me too it.
Beat me too it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8CIVIC »</TD></TR><TR><TD CLASS="quote">ok cool....so wat motor is the 1.5?
and once i put it on will i still have vtec?</TD></TR></TABLE>There are two ways for me to answer this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nice, happy Dr. Latino »</TD></TR><TR><TD CLASS="quote">
Q: What motor is the 1.5 liter?
A: D15B7, Distributor Code - TD-41U
Q: If I were to use this distributor, would my variable valve timing system still function properly?
A: Yes, the distributors only part in the input/output system that activates the valve timing change is the RPM signal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grumpy, hungover Dr. Latino »</TD></TR><TR><TD CLASS="quote">
Q:so wat motor is the 1.5?
A:
Q:and once i put it on will i still have vtec?
A:
A:
A:
i got my obd1 dist adaptor the other day
and wat if i leave out the 2nd plug that im holding and jus use the obd1 plug and connect to the obd0 harness and plug into the obd2 dist as pictured...
will it work? lmk
will it work? lmk
digitalcongo
11
Feb 15, 2007 09:01 AM
