ride height different on one side
the rear passengers side on my car is higher than all the other sides.
not much, but at least an inch. Its noticable if you look for it.
Just wondering if this is a normal occurance??
I have stock springs. not lowered or anything. stock suspension.
the only thing ive done is a rear disc swap. but I dont see how that would affect this.
Anyone else have the same problem?
yeah my ***** all crooked too
I think over time (20 years) my car has "settled". I am also stock suspension, and as far as i know original to this car that now has 200+ thousand miles.
Check your front drivers side I bet its lower then the rest of the car too and I think that is in correalation with the rear passenger being higher.
but sometimes when u remove and install your lca's u have to set the car down on the ground before you torque the bolts that connect your lca and rear subframe. try lossen them and set it bak down may this will help
DMCCOY
Suspension & Brakes
Jun 26, 2007 09:54 AM
Lil Corb
Aug 22, 2004 06:43 PM
