DOHC ZC please help
will a DOHC ZC head fit on my D16A1?
i got the dohc zc rebuilt head with JG engine dynamics
the zc came from nippon motorsports some time ago.
i paid 50$ for the engine and it needs new rings im guessing
and the main piexe to hold the crank in so i was wondering i i could just swap the rebuilt head onto the d16a1
the DOHC ZC head will bolt right onto the D16A1 - if the A1 is 86-87, the 88-91 ZC head will have different bolt patterns for the distributor and for the cylinder sensor - if the A1 is 88-89, the ZC head will have the same bolt patterns as the A1 - the ZC head has different mounting hole locations for the timing belt cover - the ZC head has a hole on the end for the driver's side engine mount that the A1 doesn't have
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyler100 »</TD></TR><TR><TD CLASS="quote">i have a 89 d16a1.
so the head will bolt on and i can use the camgears.
will it make any power gains?</TD></TR></TABLE>you have to use the D16A1 cam gears, unless you change the timing belt gear on the crankshaft - the ZC and A1 heads, as far as valves, ports, combustion chanber, etc. are the same - only differences are external where things bolt on
the A1 head uses one head bolt that is longer than the other 9 - the ZC uses all 10 bolts of the same length
before you tear into it to change the crank gear, make sure that both cranks have the same size front snout (where the pulley and crank gear go on) - both the ZC and the A1 came with 2 different size front snouts, one was 22mm and the other was 24mm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tyler100 »</TD></TR><TR><TD CLASS="quote">how would i go by doing that?</TD></TR></TABLE>just measure the hole in the crank pulley or the outside of the snout
chris riz
12
Sep 22, 2011 12:34 PM
CRX_RUS2
Nov 26, 2004 12:52 AM
