Transmission & Drivetrain Gearboxes, Differentials, Clutches
clutch pressure problems????
Old Oct 22, 2008 | 07:36 AM
yangt's Avatar
Default clutch pressure problems????
i installed a stage 1 act heavy duty clutch kit, with a act flywheel on my 99 b16. but for some reason when you step on the clutch pedal, the pressure isn't stiff. i tried over and over bleeding the slave cylinder. and is it normal for the bleeding process, for the clutch pedal having no pressure at all?(it fells like no fluid or pressure at all). what could be the problem?
Old Oct 22, 2008 | 10:00 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: clutch pressure problems???? (yangt)
do you have any pedal pressure at all? Does it make the clutch work or not?
Old Oct 22, 2008 | 10:33 AM
yangt's Avatar
Default Re: clutch pressure problems???? (Richard Noggin)
the clutch has no pressure when your bleeding the clutch master cylinder. but when you close the slave cylinder after bleeding, the pressure builds up a little bit(feels like a stock pressure type). but my buddy has the same set up, and his has a lot of pressure. the clutch works fine. but when bleeding, the clutch pedal would drop freely with no pressure. is that normal? most other cars that i bleed, it doesn't drop freely.
Old Oct 22, 2008 | 10:43 AM
yes it's normal if you bleed the slave, the pedal will in fact fall to the floor. I would bleed the slave there homie...not the master. Why do you think you should start with master? I would start with slave and bleed from there.
Chris H.
https://honda-tech.com/zerothread?id=813797
Old Oct 22, 2008 | 10:44 AM
yangt's Avatar
what i mean was the slave cylinder.
Old Oct 22, 2008 | 10:54 AM
ok, follow the link above and make sure you're doing it right, from there we'll try and figure out what's up.
civic=goodgasmileage
Honda Civic (2001 - 2005)
Jun 3, 2009 02:33 PM
94accord718
Sep 10, 2007 01:22 PM
b20acura
Jan 9, 2007 10:24 AM
fridayfred3p
Apr 27, 2006 03:11 PM
HiAssHell
Nov 5, 2005 05:04 PM
