Tucking 15x8's?
So i just got some 15x8 10 offset for my dc, and i love the offset im trying to figure out ways to get them to camber a bit for being lower, If i was to get camber kits all the way around could i make them negative with that? Also im getting the fenders rolled Friday i would really like to tuck the front wheels a bit.
Ingalls "camber kit", the one that uses sliding UCA bushings. Install backwards (so it adjusts from stock to more negative instead of positive). You'll need to create a little clearance with a BFH, but its better than killing your suspension travel with a camber adjusting UCA.
For the rear, nearly all camber kits work the same. Use a good brand name, and rubber bushings (unless you like the polyurethane squeak).
pcorad
Dec 1, 2002 08:09 PM
