JDM gsr block, pr3-4 head. what head gasket to use???
Old Oct 21, 2008 | 11:41 PM
project-boosteD's Avatar
Default JDM gsr block, pr3-4 head. what head gasket to use???
i just blew my headgasket, i was using a 3 layer and what kind i dont know, i got a built head, built block running 8.1 comp. with a block guard. running 15lbs on low and 20 on high.... what headgasket do i need to use?... what application do i buy it for? are all b-series vtec head gaskets the same?... where and what kind of gasket to purchase would be helpfull, so far ebay is the only place i've found head gaskets... and i dont wanna buy from them, one to many bad experiences
Old Oct 22, 2008 | 02:58 AM
DaveF's Avatar
Default Re: JDM gsr block, pr3-4 head. what head gasket to use??? (project-boosteD)
you can use an OEM b16 or Gsr head gasket.
Old Oct 22, 2008 | 08:09 AM
bump...
thanks for the info man, will a stock one hold up, aren't stock gaskets 3 layer as well?
what if i use 2 gaskets?
where can i get a high boost gasket?
Old Oct 22, 2008 | 09:47 AM
thatblkguy's Avatar
just use the oem one.
a 2 layer will give you a higher CR.
Old Oct 22, 2008 | 10:22 AM
TheShodan's Avatar
Moderator
Default Re: (project-boosteD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project-boosteD &raquo;</TD></TR><TR><TD CLASS="quote">bump...
where can i get a high boost gasket?</TD></TR></TABLE>
1) At 8.0:1, you're already MORE than low enough as it is. hopefully with the turbo you chose, it will not effect your acceleration too bad.
2) Oem is fine, you will not need any "boost gaskets". stacking 2 headgaskets together is just a reliable possibility
Old Oct 22, 2008 | 12:03 PM
even at 20lbs of boost?
thought stock gaskets can only hold 10?
Old Oct 22, 2008 | 12:20 PM
D@nnY's Avatar
30 psi and 670 hp and i used a stock gasket p30 and p72 gaskets are the same thing
Old Oct 22, 2008 | 02:37 PM
LastGenEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by project-boosteD &raquo;</TD></TR><TR><TD CLASS="quote">even at 20lbs of boost?
thought stock gaskets can only hold 10?</TD></TR></TABLE>
I only use Honda HG's
Old Oct 22, 2008 | 02:43 PM
Schister66's Avatar
Man U FTW
come again....
h22_crx
Nov 20, 2006 08:31 PM
StreetEG
Jul 7, 2006 08:45 PM
sickerhatch
Apr 16, 2005 10:14 AM
9seccivicsi
Jun 3, 2004 08:53 PM
InfamousRS
May 31, 2002 03:27 PM
