turn signal problem. NEED HELP..!!
OKAY, HERE'S THE SITUATION. I HAVE BEEN DRIVING MY CAR WITHOUT FRONT BUMBER TURN SIGNALS FOR ABOUT A YEAR ABD A HALF AND I FINALLY WANT TO PUT THEM BACK ON. MY DRIVER SIDE WIRES GOT RIPD OFF WITH MY FENDER LINERS ON THE FREEWAY. I RECONNECTED EVERYTHING. NEW WIRES ON DRIVER SIDE. AND IT NOW WORKS(DRIVER SIDE). BUT PASSENGER SIDE DOESNT WORK. ORGINAL WIRES AND SOCKET WITH BULB. GOT NEW BULBS AND STILL DOESN'T WORK. PLEASE HELP??? PASSENGER SIDE WAS WORKING BEFORE( A YEAR AND A HALF AGO.)
SO YOU WERE DRIVING YOUR CAR FOR A YEAR AND A HALF WITH BARE WIRES HANGING? MOST LIKELY THE SOCKET THAT HOLDS THE BULB WHEN BAD. BEFORE YOU CHANGE IT HOWEVER, GET A TEST LIGHT AND SEE IF THERE IS POWER IN THOSE LINES.
No I had cut the bare wires and taped it after it ripd. There's two sockets. 1 big and 1 small. I believe the big socket is bad. I took the small socket and switched it to the driver side. It works on the driver side.
kefka
May 22, 2003 11:23 AM
