No fuel to the engine
Old Oct 21, 2008 | 09:11 AM
Sephrin's Avatar
Default i need help please!!!!!!!!!!!!!!!!!!!!!!
my car ( 89 Ls) isnt gettin fuel to the engine, it has a new pump, filter, and main relay. the pump primes when i turn it to on, but no gas gets to the filter by the engine. I am desperate, please if u have any suggestions tell me
Old Oct 21, 2008 | 09:41 AM
AWD Terror's Avatar
Default Re: i need help please!!!!!!!!!!!!!!!!!!!!!! (Sephrin)
Did you replace the pump with a stock one? Maybe it's wired wrong?
Not 100% if you can do this on our cars or not but:
If you have access to the fuel pump still, wire it hot. Let it run for a bit and see if it gets any gas. This will let you know that the lines are not blocked and the pump is working.
Old Oct 21, 2008 | 03:34 PM
Sephrin's Avatar
Default Re: i need help please!!!!!!!!!!!!!!!!!!!!!! (AWD Terror)
ok, there is no fuel coming out of the pump, so the blockage is between the tank and the pump somewhere. if you have any othe advice please feel free to share.
i used to have a 66 chevy truck, so the import cars i know nothing about and i will take all teh help i can get
thank you
Old Oct 22, 2008 | 06:18 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephrin &raquo;</TD></TR><TR><TD CLASS="quote">ok, there is no fuel coming out of the pump, so the blockage is between the tank and the pump somewhere. if you have any othe advice please feel free to share.
thank you</TD></TR></TABLE>
Which filter did you change? I think there is one in the tank too. Pull the pump out an put it into a bucket of water. Hook it up and see if it works. Make sure you get all the water out before you put it back into the tank.
Old Oct 22, 2008 | 08:46 AM
Sephrin's Avatar
OK problem was figured out. just for you own knowledge if you have a MASTER brand fuel pump make sure the wires are on right. this brand of pump has a reverse circut and the pump will blow backto the tank instead of pulling to the engine if the wires are backwards.
again MASTER brand pump can go in reverse if wired wrong, thus making it impossible to get fuel to engine.
thank you for all th help, i wouldnt have found that out if i didnt try what you guys told me in the first place. many thanx. i have a way to go see my daughter again.
Old Oct 22, 2008 | 09:37 AM
AWD Terror's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">Maybe it's wired wrong? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sephrin &raquo;</TD></TR><TR><TD CLASS="quote">OK problem was figured out. just for you own knowledge if you have a MASTER brand fuel pump make sure the wires are on right. this brand of pump has a reverse circut and the pump will blow backto the tank instead of pulling to the engine if the wires are backwards.
thank you for all th help, i wouldnt have found that out if i didnt try what you guys told me in the first place. many thanx. i have a way to go see my daughter again.</TD></TR></TABLE>
airmaxbri
Mar 29, 2010 11:44 AM
eastbayg
Sep 15, 2008 06:48 PM
EKSedAndy
Nov 12, 2007 10:22 AM
ArchAngel Sabastian
Aug 18, 2003 11:52 AM
