93 integra with b16a swap need help
Old Oct 21, 2008 | 08:19 PM
stangracer84's Avatar
Default 93 integra with b16a swap need help
i just recently bought a 93 integra and am having problems with it. this is my first honda and i am not familair with them so i could use some help. first it is getting horrible gas milage(about 110 miles per full tank). second the vtec is not working. third it is throwing a camshaft postion sensor code. it has a b16a swap in it so i have nothing to compare the engine too so i can try to fix them problems. also if i let off of the gas and throw it into neutral it will rev way down like 200-400 rpms and the oil light will pop on and then off. sometimes it will die when i let off and let it rev down. it isnt burning any oil just alot of gas. any help would be great.
Old Oct 21, 2008 | 08:21 PM
StayKrafty's Avatar
For vtec, check the wiring, and make sure it has the correct ecu, Ive seen many honda's being sold with incorrect ecu's. For the rest, I have no idea.
Old Oct 21, 2008 | 08:29 PM
Default Re: (mybikeisblack)
like i said before i know nothing about hondas. i know where the ecu is but what am i looking for so i know if it is the right one or not. thanl you for your help.
BMC125
13
May 13, 2012 11:47 AM
civic_tuner
13
Aug 18, 2005 04:58 PM
