s300 help
Old Oct 21, 2008 | 06:31 PM
laziebun's Avatar
Default s300 help
I want to lean this area out a little...where the four are highlighted colum 3 and 4 and at 1000 and 1250rpm.
do i just hit he + icon on top?
If it is, then its not working, what do i have to do?
Old Oct 22, 2008 | 03:17 PM
postman's Avatar
Default Re: s300 help (laziebun)
drag mouse over boxes to highlight, hit minus button, then upload
Old Oct 22, 2008 | 05:35 PM
laziebun's Avatar
i've done that, but there is no change in my A/F
Modified by laziebun at 8:44 PM 10/22/2008
Old Oct 22, 2008 | 09:26 PM
mtber's Avatar
Default Re: (laziebun)
Did you hit the minus button just once ?
Old Oct 23, 2008 | 04:42 AM
laziebun's Avatar
4-5 times
Old Oct 23, 2008 | 01:21 PM
postman's Avatar
what are you using to monitor a/f
Old Oct 23, 2008 | 06:54 PM
laziebun's Avatar
Default Re: (postman)
LC-1 on my laptop
Old Oct 23, 2008 | 08:42 PM
mtber's Avatar
If you want to make sure your wideband is working properly do something drastic such as ctrl a, then ctrl j, 10 percent fuel, click ok.... (Do this to both your high cam & low cam fuel tables)
Old Oct 24, 2008 | 03:16 AM
laziebun's Avatar
Default Re: (mtber)
QUOTE=mtber]If you want to make sure your wideband is working properly do something drastic such as ctrl a, then ctrl j, 10 percent fuel, click ok.... (Do this to both your high cam & low cam fuel tables)[/QUOTE]
what is that suppose to do?[
Old Oct 24, 2008 | 07:24 AM
mtber's Avatar
Add a lot of fuel to your tables...
Old Oct 24, 2008 | 12:29 PM
laziebun's Avatar
Default Re: (mtber)
so do i add 10 to "Percent austment" "Add to selected values" or "Set selected values to"???
killer833
Engine Management and Tuning
Jan 3, 2014 07:07 PM
yungkhmer
Nov 21, 2012 03:09 AM
91b18a1ls
18
Jun 4, 2012 10:24 AM
onekoop
Nov 25, 2004 12:10 AM
draco067
Jul 22, 2003 04:28 AM
