car smells bad when AC on, what is the solution?
everytime I put on the AC, it smells like mold or something, anyone have this problem? what is the solution? do I can to clean something? thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EJ8_Enthusiast »</TD></TR><TR><TD CLASS="quote">move to Michigan.. low of 31 tonight. </TD></TR></TABLE>
LMFAO!!!! op, you prolly have a dead animal in your dash. take it apart and check.
Underneath your car you'll find a tube that drains condensation from the system (ever notice a puddle of water underneath a car with it's AC on?). If it gets plugged, water can well up leaving a perfect environment for mold to grow, hence the smell. This is actually quite common. Try sticking a piece of wire up through the tube to loosen whatever may be blocking it.
if all functions and parts of the system are working, bacteria can grow ont he evaporator itself, and newer cars actually have a biocide coating on the evaporator for this reason, look up wynns aircofresh and use that, or a product called contracept thats what we use at my dealer i work at. they work AMAZING if you dfollow the directions to the letter
