help changing clutch master on 01
Old Oct 21, 2008 | 02:43 PM
hawtsoss's Avatar
Default help changing clutch master on 01
Hey I am currently working on changing my master clutch cylinder and i have gotten all the bolts and everything off except for the little pin in the bolt that holds the linkage from the pedal to the cylinder, its basically like a bobby pin and I bent it a little but i was wondering if anyone had any advice or techniques to get the damn thing off, thanks in advance
Old Oct 21, 2008 | 02:44 PM
dagle's Avatar
Default Re: help changing clutch master on 01 (hawtsoss)
push it out the way its suppose to go out..
Old Oct 21, 2008 | 02:47 PM
hawtsoss's Avatar
Default Re: help changing clutch master on 01 (dagle)
believe it or not I already tried that and like i said it is a little bent so it wont go through, should i try to cut it or something?
Old Oct 21, 2008 | 03:39 PM
hawtsoss's Avatar
ok i got the pin out and now i need instructions on how to "bench bleed" the cylinder before i put it in, if anyone can help that would be awesome
Ajr
Honda S2000
Sep 21, 2014 11:24 AM
phookie
Jan 27, 2009 08:25 PM
jdmcivicferio
Apr 9, 2004 09:44 PM
