WTB::... need HELP! MECHANIC anyone
1991 honda crx si w/b16
im having trouble with my car.b16 was recently put in.
the problem im having with the car is when i give it gas,the passenger wheel shakes pretty bad and when rolling it makes like some sort of popping noise.i cant figure out what it is...anyone in the 562 area (norwalk,artesia,cerritos) or from any area if you dont mind driving,like to come check out my car and maybe fix it for me? please let me know asap.thank you!!............................................. ..............
i jacked up my car.i went under and spun the passenger wheel with my hand.i noticed it will spin normal and as it goes.it gets harder and get stuck a little,then pop.then free up again.spin.get harder.stuck and pop again...any ideas?
Modified by efrex at 6:35 PM 10/21/2008
put ur car on some jack stands if u can ..once on the stands give the car gas and have someone take a look at the passenger side axle
kinda sounds like a wheel bearing or axle. but for some reason im kinda leaning toward wheel bearing.
try jacking it up again and move the wheel slightly (left and right) and (up and down) if it has a good amount of play you have a bad wheel bearing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efrex »</TD></TR><TR><TD CLASS="quote">got some response,thanks fellas..ttt</TD></TR></TABLE>
take your wheel off, spin hub. hear a grind. your wheel bearings out.
i replaced my hub.
mabey get an alignment if you havent.
i replaced my hub.
714Luder
Dec 17, 2001 12:26 PM
