wierd electrical problem
Old Oct 21, 2008 | 10:16 AM
boosted_EM1's Avatar
Default wierd electrical problem
my friend has a 92 si, there is a problem when he uses his blinkers. if he turns the right one on it will stay on and not blink, and if he turns the left on one all of the light dash lights will start to blink along with the corner and head lights. im not sure of the exact order everything is going but i will get more info later. any ideas? also he has boost and oil pressure guages but they work fine. we checked all the wiring for those and it seemed fine.
Old Oct 21, 2008 | 11:51 AM
drSquish's Avatar
Sounds like someone rewired something with a blindfold or its a simple prank. I'd check the connections on the blinker relays and make sure nothing isn't improperly seated ( steady blinker). As far as the steady blinker goes, the relays work on resistance, so you might have a dead relay if your bulbs and the wiring to them are fine. The other one must be wired wrong.
Old Oct 21, 2008 | 12:03 PM
Default Re: (drSquish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drSquish &raquo;</TD></TR><TR><TD CLASS="quote">Sounds like someone rewired something with a blindfold or its a simple prank. I'd check the connections on the blinker relays and make sure nothing isn't improperly seated ( steady blinker). As far as the steady blinker goes, the relays work on resistance, so you might have a dead relay if your bulbs and the wiring to them are fine. The other one must be wired wrong.</TD></TR></TABLE>
thanks well have to do that tonight anything others?
Old Oct 21, 2008 | 04:52 PM
Default Re: (boosted_EM1)
Ok so these are the updated symptoms...when the lights are on...the right blinker stays on but doesnt blink...when the lights aren't on the blinker makes the hazards flash and the gauge lights flash as well... when the boost and oil gauges were wired in everything worked fone for a couple months and just started acting up...so i doubt it was anything with the wiring that was altered.
Old Oct 22, 2008 | 05:43 AM
drSquish's Avatar
madness. trace everything out with a set of schematics
Old Oct 22, 2008 | 08:31 AM
Endo-land's Avatar
The first thing to do is make sure that you do not have any fuses in spots that are not supposed to; this was doing some crazy stuff in my car.
Old Oct 22, 2008 | 08:39 AM
drSquish's Avatar
Default Re: (Endo-land)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Endo-land &raquo;</TD></TR><TR><TD CLASS="quote">The first thing to do is make sure that you do not have any fuses in spots that are not supposed to; this was doing some crazy stuff in my car.</TD></TR></TABLE>
x2
Old Oct 22, 2008 | 12:09 PM
yeah were going to go over the wiring tonight or tomorrow. but i dont think it would be a fuse because it has been fine for about a month.
Old Oct 22, 2008 | 05:41 PM
ttt for more tips
Old Oct 23, 2008 | 07:53 AM
anything?
teggy182
Jul 28, 2008 05:38 PM
Diaz90
Honda Civic (2006 - 2015)
Mar 10, 2008 05:11 PM
5poonhatch
May 26, 2005 10:33 PM
MintyDip
Audio / Security / Video
May 1, 2005 09:05 PM
InTeGrA B18b1
Jul 14, 2004 05:50 PM
