front camber kit
Old Oct 21, 2008 | 07:21 AM
Rease3's Avatar
Default front camber kit
what is a good choice and what do i need to bolt it up right out of box? do i need to get new bushings to go on the end?
Old Oct 21, 2008 | 08:20 AM
pettyboy69's Avatar
it depends on what kind and how cheap of a kit you buy that will determine if you need to buy new bushings or not what kind of kits have you been lookin at?
Old Oct 21, 2008 | 09:51 AM
Rease3's Avatar
Default Re: (pettyboy69)
well this is the problem that i am having
went to get an alignment today and they said they couldnt do it because i need to replace upper ball joint and outter tire rod. so i went and bought the parts but i was wondering since there is not alot of manufactures that make uca for 90 civic should i just get adjustable upper control arms or replace the ball joint? if so what brand control arms?
Old Oct 21, 2008 | 10:09 AM
Tyson's Avatar
Default Re: front camber kit (Rease3)
i dont suggest you get any camber kit.
just replace the upper control arms and tie rods with stock OE units and then get your car aligned.
disregard the camber measurements, its more important your toe is in spec.
Old Oct 21, 2008 | 10:35 AM
Rease3's Avatar
Default Re: front camber kit (Tyson)
well where can i get new ball joint pressed in at?
Old Oct 21, 2008 | 10:49 AM
Tyson's Avatar
any shop has a press. you ahve to make sure you have upper control arms with presed balljoints, not welded in, to reuse the arm.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JOE BD-0 &raquo;</TD></TR><TR><TD CLASS="quote">Stock replacement parts.....not adjustable.......
SPC part # 67075 = spendy....$40 each, but with a cool red boot......
Beck/Arnley Worldparts(nashville TN)=part # 101-4786....have not tried these, but they are probably cheaper....
Good Luck......</TD></TR></TABLE>
or just buy a whole new arm. its $90 each and comes with everything new.
Old Oct 21, 2008 | 11:11 AM
Rease3's Avatar
do you have the link to buy the whole arm?
Old Oct 21, 2008 | 11:19 AM
Tyson's Avatar
links can be found in the faq.
russianswty
Mar 9, 2007 10:26 PM
Speed Kills
Sep 1, 2006 08:42 AM
JDM KID 510
Suspension & Brakes
11
Aug 29, 2006 05:17 PM
turbotime
Apr 14, 2005 09:00 AM
