Turn Signal not working
Put my crx back together after 3 years. Works fine but I noticed the driver sided front turn signal didn't work. The passenger side worked but not the left. The in-car arrow did not light up at all. The rear driver signal didn't work either. The rear flashes when I cut on the hazzards but not the turn signal. the too front upper hazzard lights also worked just fine. The driver side bumper signal is the only one that doesn't work.
I changed the following.
The bulb itself
Flasher Signal relay
under the dash fuse
None of this seemed to fix the problem.
Thoughts?
The bulb itself
under the dash fuse
Thoughts?
HondaAccord333
Feb 19, 2018 08:04 AM
rkrone
14
Aug 26, 2006 06:38 AM
