my b16 tranny grinds in high rpm,s but in low the shifting is fine need advice!!!!
My best guess would be syncros. probably not completely bad... but worn. Its pretty common
My tranny did the exact same thing. It completely went away with a bottle of synchromesh and Royal Puple oil.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by miamiboy91 »</TD></TR><TR><TD CLASS="quote">do i have to go to chevy to get that fluid</TD></TR></TABLE>
You can go to your local Pepboys and buy Pennzoil Synchromesh.
do what i did i took the tranny apart and took the rounded edge off and made them sharp agan i used a super flat thin file took me 4 hours but after words it shifts like a dream only thing u cant fix is the shift collers there a halo type ring with teeth on the inside if thoes are messed up bad then u need a rebuild if not u can get away with fileing them
ok i got the stuff but i dont have a dip stick and i dunno how much it needs i think i have to much because i could shift at higher rpm,s but still mild grind
The oil takes a while to coat your synchros. If I remember correctly, it took about 2 weeks for the grinding to go away completely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxblues »</TD></TR><TR><TD CLASS="quote">mine did the same. just replaced the old tranny fluid with honda mtf</TD></TR></TABLE>
I just did a full tranny fluid change using Honda MTF. My trans is a JDM YS1 and it had a third gear grind which wasn't even subtle at low speeds.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89Turbo_Angel »</TD></TR><TR><TD CLASS="quote">The oil takes a while to coat your synchros. If I remember correctly, it took about 2 weeks for the grinding to go away completely. </TD></TR></TABLE>
It took me about 5 days of solid driving for the transmission to feel like my S2000's (nice and smooth)
Next time I may give the synchromesh a shot - but for now Honda Genuine does it for me
Well if you wana try it out andits not your daily driver you can just put in the syncromesh and see if that works if not then pull the tranny out and replace your syncros or shave em sharp which is what i would do its the safest and best bet
