Transmission & Drivetrain Gearboxes, Differentials, Clutches
Help, How to undo bung/bolt with countershaft clip under it?
Old Oct 21, 2008 | 12:11 AM
majinsoftware's Avatar
Default Help, How to undo bung/bolt with countershaft clip under it?
Iv just blowen another box up and now I have 3 wreaked boxs in my guarage so im thinking of pulling them all apart and using there parts to make 1 good box.
What I want to know is there some trick to getting that bung/bolt undone? Iv tried with one box already and it just stripped it out so now im going to have to weld a socket piece on to it.
Thank you for your help.
Old Oct 21, 2008 | 10:33 AM
Aquafina's Avatar
Huh?
If you're talking about the plug that goes here
Just put a 3/8(D) or 1/2(B/H) breaker bar in it and break it loose. lefty loosey.
If you're talking about the bolt that holds the CSB retaining plate in, bend back the circlip and put a 10mm socket on it and break it loose.
Old Oct 21, 2008 | 03:21 PM
yup ^^^ that plug, Stripped out two of them now, They just wont undo so im going to have to wield sockets onto both of them.
Old Oct 21, 2008 | 03:27 PM
Aquafina's Avatar
I wouldn't waste a socket.
Just have some barstock welded into a T shape. Bottom of T gets welded onto the plug. vice grips or some pipe on the top of the T to break it loose. Keep the welds on the plug as cold as possible and away from the edge.
Old Oct 25, 2008 | 01:50 AM
thanks, Really helped and saved me a socket lol.
This is what iv found inside lol.
Old Oct 25, 2008 | 01:07 PM
Aquafina's Avatar
^Thats common.
chris d
Aug 7, 2015 02:08 PM
andyz
Mar 22, 2012 05:05 AM
beastman@
Jul 13, 2008 04:58 AM
windg@t
Jan 10, 2005 10:08 AM
hellas
Jan 21, 2003 12:33 PM
