Running Lights not working at all
Old Oct 20, 2008 | 08:17 PM
swells's Avatar
Default Running Lights not working at all on CRX
I put new relays ( followed the wiring to the relay and replaced) on and there still not working. The fuses are all good....any help please...Thanks all
Old Oct 21, 2008 | 12:37 PM
HaulingAddison's Avatar
Default Re: Running Lights not working at all on CRX (swells)
Well, you've already checked the fuses and the relays, now check the groud wires behind the lightbulbs and the ground box thing kind of by the side markers under the hood. If those are all good, do a volt chech at the switch and headlights. If you don't have power at the headlights, do a continuity check on the light switch to see if power is going threw the switch.
Old Oct 21, 2008 | 01:38 PM
vanrij's Avatar
Are you talking about the parking lights?
Old Oct 21, 2008 | 02:13 PM
swells's Avatar
Default Re: Running Lights not working at all on CRX (vanrij)
yes the parking lights...Thanks for the info..will try
Old Oct 22, 2008 | 12:50 PM
swells's Avatar
Ok i ended up getting them to work but I have to push the hazard light button in so there is a wiring issue somewhere.....
Old Oct 22, 2008 | 01:12 PM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
there is also a control module (gray box) on the back of the fuse box that runs the blinkers/parking lights (the ones next to the headlights, not the bumper lights). i had a dead parking light that only took me several hours to trace back to a burnt trace in that module.
just something else to look at....
Arodway
May 4, 2016 09:25 AM
Laz's EP
May 7, 2009 02:24 PM
Optiks.
Sep 30, 2003 07:25 AM
ImprtTuner88
Nov 19, 2002 04:09 AM
