help!! i got a oil leak on a 95 acoord ex.
Old Oct 20, 2008 | 08:00 PM
SonicRacing's Avatar
Default help!! i got a oil leak on a 95 acoord ex.
alrite heres the story guys. my sister recently gave me her 95 honda accord and i have been driving it for a few days now. i notce that when the car is running it tends to leak oil. so i check the oil pan gasket, screw and to see if it had any holes in the oil pan. nothing so i then took off the oil filter to see if that was the problem and nothing. so i did a oil change anyways and started the car it started to leak oil agian. i cleaned everything down and it seems like the leak is coming from above the oil filter and i cant tell because it so compacted .. has anybody had this problem before? anything will help.. thanks
Old Oct 20, 2008 | 08:07 PM
TheMuffinMan's Avatar
He knows where you live!
Honestly the easiest way to track down a leak is to clean off the area and then drive around and see where the new oil is.
How far above the oil filter?
Old Oct 20, 2008 | 09:09 PM
daytime's Avatar
Default Re: help!! i got a oil leak on a 95 acoord ex. (SonicRacing)
I have a 98 accord and from what I've been told, my oil leak is coming from either a bad rear main seal or a bad seal on the actual housing assembly of the rear main seal.
But that might not be your problem, just throwing out a possibility.
Old Oct 21, 2008 | 03:52 AM
P_Adams's Avatar
If you've noticed the oil leaking in the vicinity of the oil filter, it can be one of two things.
a) A leak from the an oil cooler adapter (Which would sandwich between the oil filter and the block (If so equipped) or
b) A leak from the oil pressure sensor (switch) located just above the Oil filter. It can be removed and replaced with a drive socket.
P
edited for stupid spelling mistake
Modified by P_Adams at 8:31 PM 10/23/2008
Old Oct 21, 2008 | 05:19 AM
joc1394's Avatar
Default Re: help!! i got a oil leak on a 95 acoord ex. (P_Adams)
I've had this mysterious oil leak on my '92 Accord EX too.
I've determined it'd coming from near the oil filter and just last week I found out that the Oil Pressure Sending unit is located directly above the oil filter on the F22A6 engine too. Only about 1k until my next scheduled oil change, at which point I'm going to replace the sending unit and oil pan gasket which both appear to be leaking...then wait to see what other seals have gone leaky
Thanks for the idea of checking that adapter at the oil filter P_Adams!
Old Oct 23, 2008 | 10:39 AM
mani_0130's Avatar
i had same problem with my 95 EX coupe i took the oil pressure sensor out and put some Hondabond HT on it and put it back on it was good and stopped leaking but then the oil leak came back after like 3 months. So i bought a new oil pressure sensor put hondabond HT on it and its been good and no more leaking since.
Old Oct 24, 2008 | 08:26 AM
Default Re: help!! i got a oil leak on a 95 acoord ex. (mani_0130)
thanks for the suggestion guys. i gotta take a look at it in a few hours after i get done with classes. i hope its the oil pressure sensor and nothing to hard to fix.
Old Oct 27, 2008 | 06:48 PM
alright thanks guys, it is the oil pressure sensor, only a 12 dollars fix filled with headache. i was way scared when putting it back in thinking i was going to crack the block or something since many of my friends have done it before..thanks for the help
Old Oct 28, 2008 | 05:11 AM
P_Adams's Avatar
Default Re: (SonicRacing)
Glad it worked out on the cheap end of things
P
Old Oct 28, 2008 | 07:16 AM
mani_0130's Avatar
yea seems like these sensors go bad on accords because i just replaced one on my uncles 96 sedan this past weekend.
Old Oct 28, 2008 | 07:45 AM
P_Adams's Avatar
Default Re: (mani_0130)
It's not uncommon.
It's an item stocked (even at a minimum level) by dealers.
Who wants to tie up a csutomer's car for a $14.00 Item?
P
Old Feb 28, 2009 | 07:20 PM
Bad_dude's Avatar
Which location or where about was your leak? Was it in the center toward the front a little?
Thanks.
JustCant5topMe
Aug 16, 2013 12:18 PM
mrspeedy69
14
Feb 5, 2012 11:48 AM
market525
Oct 5, 2010 04:16 AM
TheCrimsonGhost666
Jul 8, 2009 08:21 PM
srburk
Apr 6, 2004 01:36 PM
